![]() | Home > Maintenance & Modifications > grill surround |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 ![]() ![]() ![]() |
Hi
My aunt had an accident with her 90... all solved now, she's rebuilding the 90... I've managed to source almost every part (nearly new front axis, left wing, steering and panhard bars, and some other bits). But I have a doubt the grill surround she had was like the def on the pic. But the one I got, used (as that new cost almos 200€!), does not have those square holes like the small pic on the right ... Are they needed? Or can I fit the grill surround without those holes... ![]() Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
The two apertures with all the holes in (if I'm on the right track and read your post correctly) are for the intercooler to get cooling air.
On the Puma they are large apertures and an aluminium grille is riveted into place behind the holes. See here: http://www.defender2.net/forum/topic8534.h...ler+grille Not sure what the setup is on a previous model! Either way the holes are there for a reason and personaslly would not fit it without them. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 16th Jul 2012 6:23pm. Edited 3 times in total |
I thought that was the reason!
Thank you both! ![]() But that's an easy fix, to get those holes in to place, as seen on that other post ! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
but make sure its not for a right-hand drive fender
