![]() | Home > Td5 > wet floor :( |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
Wonder how any can make fire in Essex
![]() β½οΈπ’οΈβοΈπ§°πͺ |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
im border line
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 ![]() ![]() ![]() |
could it be the DRIP behind the steering wheel ?
I'm keeping right out of this not getting the cider and farmers talk
In Essex the fires never go out, at least not from the cars pushed off the road ![]() But shout it at them in German because life is also terrifying and confusing... |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 ![]() ![]() |
Mine drips in the passenger footwell from under the dash, when i get a bunch of items i will run it into LR to get all the bits done.
tack |
Yer and houses too probably with all the hair spray and what not sprayed around
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Mine too. It's quite cooling in summer for the wifes feet but winter might be another issue!! 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Mine leaks in from the top corner of the front doors / windscreen frame (both sides, worse at passenger side), presumably from where it pools in the roof channel. However, since putting the roll cage on it is nothing like as bad! Must deflect the rain or something! Yeyy!!
Great reason to add a cage. Will they do it under warranty
![]() 1995 110 300TDI 1995 90 300TDI |
110Td5 Member Since: 15 Jul 2012 Location: Miles from anywhere Posts: 18 ![]() ![]() |
Pondering a possible Td5 purchase (ideally a 110 Td5 hence my profile name) is leaking a common occurence when it rains??
At the risk of tempting fate, mine doesn't... Darren
