Home > Puma (Tdci) > Keyfob battery fixed a problem
AlisterC
Wales 2011 Defender 90 Puma 2.4 XS CSW Indus Silver
Just posting this in case it saves someone some bother...
my central locking and alarm started playing up... when i tried to lock the doors, they re opened and the alarm went off.
Tried a few things, like checking the doors were closed properly, the door and bonnet swtiches were working and lined up etc. Then, after doing a search on here, changed the battery in the keyfob, and hey presto... all working perfectly again.
Just seemed to be a strange symptom for a weak battery. Thought it would just stop working.
I'll let you know if my triumph is short lived, but in the meantime, hope it saves someone a bit of time
Post #155477 13th Jul 2012 9:50pm
ericvv
See in your profile you have a 2011 Puma. So presume you buy the annual service from a main LR dealer as required by the 3 year warranty. Should know that LR prescribes that part of the annual service is the replacement of the fob batteries. Make sure your dealer does that. I have a 2008 Puma and never had fob battery issues, so presume my dealer diligently follows the LR guidelines. I hope they do of course, as never really asked about this Wink You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #155481 13th Jul 2012 10:06pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
It would seem that AlisterC had a dud battery as the battery change in the Keyfob is part of the "B" service i.e.: every 24,000 miles or 2 years, according to the service schedule information I have, and if he has a MY 2011 wouldn't have had a "B"service yet unless he is a high milage driver. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #155493 14th Jul 2012 5:39am
AlisterC
It's sept 2011 2.4. So no service happened yet
So, it was either a dud battery or I am completely off in my diagnosis, and it was a freak of nature that the problem was fixed by this. Time will tell!
What led me to this was that the spare keyfob worked perfectly
Post #155507 14th Jul 2012 10:02am
WelshGas
Probably a dud battery. I don't know if the fobs are made for each vehicle, more likely made in large batches then synced to each vehicle, so the battery could have been live for a while before being selected. As the spare worked OK then unlikely to be the vehicle, more likely the fob or battery and I doubt if they use high quality batteries especially if it is written into the 2 yearly service to CHANGE the batteries automatically. On my wifes MX5 it says to change the battery every 5 years. Thumbs Up Thumbs Up LANDYWATCH
Post #155509 14th Jul 2012 10:41am
