![]() | Home > Puma (Tdci) > remove DPF ? |
SimonR Member Since: 28 Jun 2012 Location: Horsham, West Sussex Posts: 74 ![]() ![]() |
Notwithstanding that the DPF may be required legally.....
The pressure each sensor sees is going to be proportional to engine load and RPM. Although you could read this from the ODB2 connector and use the throttle position sensor as being proportional to load for a given RPM, I wonder if you could achieve the same thing by moving the sensors to different places in the exhaust pipe. There is a pressure drop along the length of the pipe and it may be that say one sensor in the exhaust manifold and another in the tail pipe would give sufficient pressure drop to fool it? Another option would be to replace the filter with a constriction which causes the same pressure drop. You could find out how much using a simple butterfly valve in a pipe with the sensors on either side. Once you find the right valve position, weld it in place. This strikes me as easier than trying to implement it with a micro controller + software (even for someone like me who has a lot of uC & Software experience). Si |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
The P2463 code points towards a maximum soot mass. It's not clearing itself.
I've had a few reps in recently offering DPF cleaning products. Trying this may be a better option, although perhaps just short term? Wurth and Wynns/Forte were two of them. I can't help but feel someone is making a lot of money out of DPF manufacturing, as with 'Type approved' cats. Probably me cynical as usual, but someone in a senior position in Brussels... ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
What about using the South African (non-DPF 2.2) engine map/software?
towfox Member Since: 11 Jul 2012 Location: Limburg Posts: 5 ![]() ![]() ![]() |
Hello,
-Cleaning: i thought about it, we sometimes clean DPF's with the system from Liqui Moly, ore in hardship case with an kärcher. But the Defender is two weeks old and the technician of the dealer had once a time in february same problem with another Defender and ad this time something in the DPF of the filter matrial was broken. probably its the same problem, because it did not start cleaning bevore showing the errors. -South Africa Software? OK, that's an useful information. i will talk with the dealer. regards |
I very much doubt that a dealer will apply the SA software.
Potentially could be a good 'moneyspinner' for somebody, especially if it's switchable!!!! ![]() Treat every day as if it is your last....one day you will be right!! |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
All above is what i am looking into at the moment as i am sure my turbo is stalling due to the excessive back pressure in the top part of the exhaust, my turbo was glowing cherry red last night after pulling up Shap Southbound BAS are looking at a cat style removal pipe and an euro 4 map c/w egr run close, they are busy with shows at the moment but it is their top priority when they are back in the workshop, my name is on the list as a high mileage donkey tester for it, as most people on here already know i hate my new 12 plate worst 90 i have ever owned, my 300tdi pulled trailers better, just back in Devon now A303 towing is now painfull used to be a joy in the 57plate 2.4. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
yobbie Member Since: 15 Nov 2010 Location: Isle of Wight Posts: 713 ![]() ![]() ![]() |
Has Kingofthesparks on here, removed his for an overland trip?
Yes he has, he has his own mechanic that did his before he left for China If everything is under control you are not going fast enough.
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Have not left yet , delayed due to family issues , leaving at the end of august , hoping to be home for Xmas,
Martins answer was right SA software ![]() |
Thanks, i will try to get this software.
Can you tell me against which parts you changed the DPF? Also from the SA-Modell? Regards |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
“someone is making a lot of money… someone in a senior position in Brussels”
I do hope that’s not meant to be serious… that’d be like blaming an office manager in Swansea for the four hundred quid VED on a Range Rover, or a clerk in your local tax office for any increase in income tax or pension contributions. “Brussels” is simply the HQ of European bureaucrats who - just like the UK’s Civil Service - implement the policies of the politicians YOU voted for. Peter |
Not meant to be serious, so calm down dear.
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
did you then just put a straight through section on the exhaust where the dpf was? im guessing this wouldn't be illegal or fail an mot as its making it no different to the 2.4. |
