Home > Technical > [b]Nanocom Help Alarm TD5[/b] |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
PM me your email and i'll send over the user manual for the nanocom.
10th Jul 2012 5:13pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5698 |
Me too please Jim
a.russell@virgin.net Andy |
10th Jul 2012 5:14pm |
emails sent out
10th Jul 2012 6:11pm |
Got, thanks
10th Jul 2012 6:13pm |
tazmarkuk Member Since: 24 Jan 2012 Location: Birmingham Posts: 134 |
Thanks Jim,
some bed time reading Cheers Mark |
10th Jul 2012 6:20pm |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 |
Sorry to/if I am hi jack, but can the alarm and immobiliser be deactivated by the nanocom?
Reason I ask is that I have a Toad Cat 1 alarm for insurance purposes as well as the factory fitted alarm. i HATE having two alarm fobs on the key ring, so would like the factory fitted one removed/deactivated as it once failed to un-immobilise and the Mrs was stuck at work and unable to come home and cook my dinner, which is totally unacceptable obviously!! Strong people are harder to kill and generally more useful! |
10th Jul 2012 7:19pm |
Hi, its my understanding yes it can be deactivated, mine has, not sure it was with a Nanocam though, as im trying to get mine reactivated.
Mark |
10th Jul 2012 8:23pm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Mark,
There is no alarm on or alarm off... There are a number of options that you need to select depending on the spec of your Land Rover and what level of security you want. Some functions you can ignore - as they don't do anything, but others must be selected to get the best from your alarm. As already mentioned, if you get really stuck give me a shout.
Yes... It can be set into a full poverty spec mode - where by the 10AS physically needs to be there so that the engine ECU can confirm its the alarm unit it's expecting to see (i.e. the one it's paired to).... but apart from that it will do nothing, and you can remove the LR alarm fob from your Keyring. What you really want is an integrated alarm upgrade that takes the system to an insurance approved CAT 1 spec, but uses the STD Land Rover Alarm fob or one of the integrated key/fobs.... Also available from Tim - http://www.mobilecentre.co.uk/upgrades-for...6_225.html Ian |
11th Jul 2012 6:30am |
