Home > Technical > What snorkel sealant?
Page 2 of 3 <123>
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I kid you not! It you had a solid block of hard rubber this is what it is like. I am havingto use a craft knife, I sure I heard it laughing when I used the nail polish remover! No affect at all. I thik the only thig left to do is buy some razor blades tomorrow and slice it off. I used a brand new craft knife on it and its blunt aready! I got one more that I am just going to get out of the tool box but after that I am going to give up!!!
Post #154202 7th Jul 2012 7:15pm
bob neville
If it is that hard I think I would use a flap sander in an angle grinder to get it smooth and then do as K9F said.
Health warning - flap sander in an angle grinder can do lots of damage so practice first on some scrap first if you want to try this.
2013 Defender 90 CSW - sold
Post #154205 7th Jul 2012 7:49pm
K9F
Dremmel would be my weapon of choice and be more controllable and get through it in no time at all! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154260 8th Jul 2012 8:27am
The Boy
Well this is what I got to last night.
Christ know what this stuff is.
This morning I have been attacking it with a steam gun. Not really working but when it does come of it is in some places taking the laquer and even the paint off with it.
I also norticed that the metal clips on the bottom of the LR?Mantec one have reacted with the alloy and stated to eat into it so that is another reason I will never use one of those again.
I am nearly at the point of leaving it now and hoping the safari gaskit will seal over the top of this stuff. I don't like bodging and can turn my hand to most thing s but this has nearly got me beat.
As I left it last night
As it is now after two hours with the steam gun and razor blade.
Post #154269 8th Jul 2012 9:06am
K9F
Not a bad job considering what you were up against. Thumbs Up I would smother it in Sikaflex gasket over the top another bed of Sikaflex and then snorkel. Using turps substitute or white spirits once the lot has been bolted on wipe the excess off. Job jobbed!
Thumbs Up Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154285 8th Jul 2012 10:02am
The Boy
Thumbs Up Thumbs Up
Sounds a good plan.
Just waiting for the G10 store (ebay) to deliver the sealant Thumbs Up and I will need to get a step drill form one of my suppleirs so to drill out the pilot holes to 16mm. Not one bloody diy or hardware store had one round here.
Boy
Post #154288 8th Jul 2012 10:09am
K9F
The Boy wrote:
Thumbs Up and I will need to get a step drill form one of my suppleirs so to drill out the pilot holes to 16mm. Boy
Just a quick addition/tip.......If you are very careful in aligning the template and continually 'offer' the snorkel up you don't have to take the holes out bigger than 12mm. I got away with 12mm! Why drill bigger holes than is absolutely necessary? 'Wet assemble' everything with the sealant and you should have no corrosion issues.
Post #154292 8th Jul 2012 10:56am
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The Boy wrote:
Thumbs Up Thumbs Up
Sounds a good plan.
Boy
I have a step cutter that does 16mm you're welcome to borrow. Darren
Post #154308 8th Jul 2012 11:32am
The Boy
DarrenJ wrote:
The Boy wrote:
Thumbs Up Thumbs Up
Sounds a good plan.
Boy
Thanks chap. Bow down
I might try to get away with a 12mm hole first. Will not be doing it until next weekend now.
I also have another question. This is a photo of the air filter box taken though the wing top. Are you supposed to see the filter showing through the near corner? You can see it just I the photo. I am going to strip it out during the week but initially it looks like apart from that corner it is fitting as it should do.
Post #154321 8th Jul 2012 1:57pm
mermoto
Doing a good job there 'The Boy'. I purchased some SIKAFLEX-221 Multi-purpose Sealant which I am now thinking will not be removable should I ever have to. So may not use it now after seeing your struggle. What type of sealant did you get?
Keep the pictures coming!
Mermoto
Post #154333 8th Jul 2012 3:10pm
The Boy
I use 291 but only because K9F said it was the best stuff to use I know little about sealant TBH
Boy
Post #154336 8th Jul 2012 3:17pm
ZeDefender
I took a different approach and used butyl tape (my weapon of choice) - rolled up to make a nice fat bead all around the gasket and then tightened the bolts to squash. No mess, no problem becoming unsealed (it never comes unsealed) and easily removable if you need to
I love Sikaflex 291 but I don't trust it completely to seal plastic surfaces "for ever" in places I can't see...
Just an idea Wink Tell someone you love them today because life is short.
Post #154350 8th Jul 2012 4:38pm
K9F
ZeDefender wrote:
I love Sikaflex 291 but I don't trust it completely to seal plastic surfaces "for ever" in places I can't see...Wink
Interesting quote....What do you use then that you can trust? The snorkel bolts are a considerable distance apart and a pressure fit is always better in my opinion. Laying a thick bed of sealant and pressure fitting is better than butyl unless it is really quite thick butyl. Details of 29i state "Fast cure marine adhesive/sealant and bedding compound. Ideal for bedding in skin fittings, fully waterproof, can be for below the waterline applications."
I would trust Sikaflex everytime, not heard of anyone usuing butyl tape below the waterline before, may suggest it, Condor Ferries could save a fortune.
Laughing Whistle
The Boy wrote:
I use 291 but only because K9F said it was the best stuff to use I know little about sealant TBH Boy
It is! Stick with it it will not disappoint or let you down. Leave it on your skin for more than 10 minutes and you will be stuck with it, for at least four days anyway! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154367 8th Jul 2012 5:35pm
ZeDefender
As I said, I use Sikaflex for loads of stuff and it's wonderful.
However, butyl has held our caravan together (and sealed all the windows and roof vents on), without a leak for 15+ years. On the other hand, 291 has lost its grip on my window rubber after 6 months, so I wouldn't call it flawless. Certain plastics (especially polythene) are very resistant to "permanent" sealants and this can happen after some time. This was my logic.
When warm, a thick bead of butyl squashes, sticks and seals really well permanently... until you want to remove it without a trace Thumbs Up
No, I haven't used it on my submarine Rolling Eyes but its qualities are well known where high water pressures are involved e.g. swimming pools etc.
http://www.aquabond.com/s.nl/it.A/id.115/.f
http://www.poolcenter.com/repair_supplies_anderson.htm
http://www.waternsports.com/Store/shopdisp...+Detection
Like I said Sikaflex is great, it was just my personal choice not to use it for my RAI...
Hope I haven't offended anyone with my humble opinion Whistle Tell someone you love them today because life is short.
Post #154376 8th Jul 2012 6:23pm
K9F
Not at all....Good debate is healthy! Thumbs Up Everyone is naturally entitled to their opinions and sharing experiences help those that are less informed in making the right choice or perhaps even the wrong choice of their own! They then in turn get to share theirs!
Bow down If you go through life with your head in the sand....all people will see is an ar5e!!
Post #154380 8th Jul 2012 6:28pm
Page 2 of 3 <123>
