![]() | Home > Technical > What snorkel sealant? |
If it is that hard I think I would use a flap sander in an angle grinder to get it smooth and then do as K9F said.
Health warning - flap sander in an angle grinder can do lots of damage so practice first on some scrap first if you want to try this. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Dremmel would be my weapon of choice and be more controllable and get through it in no time at all!
![]() Treat every day as if it is your last....one day you will be right!! |
Well this is what I got to last night.
Christ know what this stuff is. This morning I have been attacking it with a steam gun. Not really working but when it does come of it is in some places taking the laquer and even the paint off with it. I also norticed that the metal clips on the bottom of the LR?Mantec one have reacted with the alloy and stated to eat into it so that is another reason I will never use one of those again. I am nearly at the point of leaving it now and hoping the safari gaskit will seal over the top of this stuff. I don't like bodging and can turn my hand to most thing s but this has nearly got me beat. As I left it last night ![]() Click image to enlarge As it is now after two hours with the steam gun and razor blade. ![]() Click image to enlarge ![]() |
Not a bad job considering what you were up against.
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
![]() ![]() Sounds a good plan. Just waiting for the G10 store (ebay) to deliver the sealant ![]() Boy |
Just a quick addition/tip.......If you are very careful in aligning the template and continually 'offer' the snorkel up you don't have to take the holes out bigger than 12mm. I got away with 12mm! Why drill bigger holes than is absolutely necessary? 'Wet assemble' everything with the sealant and you should have no corrosion issues. ![]() Treat every day as if it is your last....one day you will be right!! |
DarrenJ Member Since: 07 May 2012 Location: North Beds Posts: 312 ![]() ![]() ![]() |
I have a step cutter that does 16mm you're welcome to borrow. Darren |
Thanks chap. ![]() I might try to get away with a 12mm hole first. Will not be doing it until next weekend now. I also have another question. This is a photo of the air filter box taken though the wing top. Are you supposed to see the filter showing through the near corner? You can see it just I the photo. I am going to strip it out during the week but initially it looks like apart from that corner it is fitting as it should do. ![]() |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Doing a good job there 'The Boy'. I purchased some SIKAFLEX-221 Multi-purpose Sealant which I am now thinking will not be removable should I ever have to. So may not use it now after seeing your struggle. What type of sealant did you get?
Keep the pictures coming! Mermoto |
I use 291 but only because K9F said it was the best stuff to use I know little about sealant TBH
Boy |
I took a different approach and used butyl tape (my weapon of choice) - rolled up to make a nice fat bead all around the gasket and then tightened the bolts to squash. No mess, no problem becoming unsealed (it never comes unsealed) and easily removable if you need to
I love Sikaflex 291 but I don't trust it completely to seal plastic surfaces "for ever" in places I can't see... Just an idea ![]() But shout it at them in German because life is also terrifying and confusing... |
Interesting quote....What do you use then that you can trust? The snorkel bolts are a considerable distance apart and a pressure fit is always better in my opinion. Laying a thick bed of sealant and pressure fitting is better than butyl unless it is really quite thick butyl. Details of 29i state "Fast cure marine adhesive/sealant and bedding compound. Ideal for bedding in skin fittings, fully waterproof, can be for below the waterline applications." I would trust Sikaflex everytime, not heard of anyone usuing butyl tape below the waterline before, may suggest it, Condor Ferries could save a fortune. ![]() ![]()
It is! Stick with it it will not disappoint or let you down. Leave it on your skin for more than 10 minutes and you will be stuck with it, for at least four days anyway! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
As I said, I use Sikaflex for loads of stuff and it's wonderful. However, butyl has held our caravan together (and sealed all the windows and roof vents on), without a leak for 15+ years. On the other hand, 291 has lost its grip on my window rubber after 6 months, so I wouldn't call it flawless. Certain plastics (especially polythene) are very resistant to "permanent" sealants and this can happen after some time. This was my logic. When warm, a thick bead of butyl squashes, sticks and seals really well permanently... until you want to remove it without a trace ![]() No, I haven't used it on my submarine ![]() http://www.aquabond.com/s.nl/it.A/id.115/.f http://www.poolcenter.com/repair_supplies_anderson.htm http://www.waternsports.com/Store/shopdisp...+Detection Like I said Sikaflex is great, it was just my personal choice not to use it for my RAI... Hope I haven't offended anyone with my humble opinion ![]() But shout it at them in German because life is also terrifying and confusing... |
Not at all....Good debate is healthy! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
