![]() | Home > Puma (Tdci) > fitting a pre fuel filter |
MAXS90 Member Since: 02 Feb 2009 Location: Churchristch Posts: 1 ![]() ![]() |
Hi we have fitted several Racor filter/water traps to Trany Defenders with no problems. We fit them in the rear of the right hand rear wheel arch and plumb them in before the main filter. The only problem we have is the pipe size is not standard for the fittings so we have special ferules made. System must be air tight as Tranys use suction for fuel supply.
is there a problem with diesel in Australia ?
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Which model Racor are you fitting? Cheers, Tim (By the way, we prefer the term trans-fender ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Should be OK, but is it necessary to do it?
LR Arduous servicing includes draining the fuel filter (Stanadyne are OEM for the Puma filter application anyway) and there is a water in the fuel warning flag within the powertrain ECU. Really, if you do need this, then there is an issue somewhere like contamination in the tank already. As mentioned by MAXS90 if you are going to do it, the Puma sucks up fuel from the tank using the LP part of the fuel pump on the side of the engine, so it needs to be airtight. |
deep down Member Since: 02 May 2012 Location: France Posts: 204 ![]() ![]() ![]() |
Any further update on this? Did you fit a pre-filter.
I'm interested as I'm heading to Morocco for a 3000 km Raid/Competition in April. Everyone who's going (No Defender owners) says it's necessary as every morning there is water in the fuel bowl due to condensation and poor fuel. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Have a look here I got a couple for my rib off them.
http://www.asap-supplies.com/marine/fuel-filters-and-elements |
