Home > Puma (Tdci) > fitting a pre fuel filter
dasha
Australia 2010 Defender 110 Puma 2.4 SW Stornoway Grey
I am thinking of fitting a Stanadyne FM100 30 micron pre fuel filter. I have gotten conflicting advice yes fit one to protect the motor, no it might damage or at least put the engine into limp mode if the filter gets blocked, if I fit one it will have the in dash alert light alerting I have water etc in the fuel, as well as a hand pump to purge any air in the system . I am thinking of fitting it in front on the OME filter, any advice will be greatly appreciated as I,m not sure which way to go. I have been told by L/ROVER AUST that it shouldn't effect my warranty hopefully never have to test that. series 3 swb gone . o5 defender gone
Post #150056 13th Jun 2012 4:36am
MAXS90
New Zealand
Filter
Hi we have fitted several Racor filter/water traps to Trany Defenders with no problems. We fit them in the rear of the right hand rear wheel arch and plumb them in before the main filter. The only problem we have is the pipe size is not standard for the fittings so we have special ferules made. System must be air tight as Tranys use suction for fuel supply.
Post #154115 7th Jul 2012 10:07am
is there a problem with diesel in Australia ?
Post #154124 7th Jul 2012 10:53am
Tim_NZ
Australia
Re: Filter
Which model Racor are you fitting?
Cheers,
Tim
(By the way, we prefer the term trans-fender Smile )
Post #154146 7th Jul 2012 1:06pm
wslr
Should be OK, but is it necessary to do it?
LR Arduous servicing includes draining the fuel filter (Stanadyne are OEM for the Puma filter application anyway) and there is a water in the fuel warning flag within the powertrain ECU. Really, if you do need this, then there is an issue somewhere like contamination in the tank already.
As mentioned by MAXS90 if you are going to do it, the Puma sucks up fuel from the tank using the LP part of the fuel pump on the side of the engine, so it needs to be airtight.
Post #154157 7th Jul 2012 3:01pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
Any further update on this? Did you fit a pre-filter.
I'm interested as I'm heading to Morocco for a 3000 km Raid/Competition in April. Everyone who's going (No Defender owners) says it's necessary as every morning there is water in the fuel bowl due to condensation and poor fuel.
Post #192704 11th Dec 2012 12:36pm
mick
Have a look here I got a couple for my rib off them.
http://www.asap-supplies.com/marine/fuel-filters-and-elements
Post #192802 11th Dec 2012 7:32pm
