Home > Td5 > Not responding to keyfob
Martin
Site Admin
Are there any reasons, other than a flat keyfob battery, why my Td5 won't respond (immobilise/unimmobilise/flash hazards) to pressing the keyfob buttons?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #154137 7th Jul 2012 11:54am
bob neville
Long shot but does the fob need to be re sync'd ?
With vehicle unlocked, take battery out of fob and then hold both buttons down for 10 seconds to drain residual power.
Battery back in then press lock four times and unlock once. That will sync the fob back to the ECU.
2013 Defender 90 CSW - sold
Post #154145 7th Jul 2012 12:38pm
Martin
Site Admin
I'll give that a shot, thanks Bob  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #154147 7th Jul 2012 1:35pm
sparkylee
2012 Defender 110 Puma 2.2 DCPU Santorini Black
This is why I love this forum
You guys have so much knowledge
Bow down It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech
FFRR 4.2 vogue
Renault traffic auto
PT crusier convertible
Laika x700 Motorhome
Post #154152 7th Jul 2012 2:03pm
Martin
Site Admin
Absolutely, changed the battery and went through Bob's procedure and it's all ok again!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #154181 7th Jul 2012 5:47pm
Bob for president Thumbs Up
Post #154187 7th Jul 2012 6:17pm
JWL
Had a mate phone me up not too long ago where the same thing had happened.............at 11 o'clock at night Rolling Eyes He'd got back to his Disco 1(near enough same set up alarmwise) and couldn't get it to start, he'd opened it but I reckon as he was putting his kit back in he had been pressing the button in his pocket when out of range. Whilst he'd been faffing about trying to sort it out himself he'd set the alarm off, that made him popular with the wildlife! Just popping the batteries out and leaving it at least 10 seconds before putting them back in and resyncing sorted it out Thumbs Up
Post #154210 7th Jul 2012 8:23pm
Franco-British
United Kingdom 2015 Defender 110 Puma 2.2 SW Santorini Black
Any idea which relay (FL) "controls" the keyfob /
I went through Bob's recommendation a few weeks ago and everything worked fine for a while but now, after a few days of not using the keyfob to lock / unlock, I have got no immobiliser (I stick the key, turn it and the car starts) and the keyfob won't re-sync. I tried the fuses and they all seem fine, INCLUDING F8 which triggered the alarm horn when removed?!? I am confused. Thank you
Post #813403 3rd Feb 2020 4:30pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
We think Land rover alarms are odd.
Two years ago I was staying in Plymouth for a few days and needed a motor as I hadn't taken mine down on a 400 mile each way trip, anyway hired a Jeep Grand Cherokee with 200 mile on the clock arrived at the Hotel and was getting luggage out of the back when the doors locked and the auto boot lid started to close I jammed the bags on the closing lid and grab the keys off the boot floor. It turns out there is a setting from the factory which after 5 minutes locks all doors including the boot, the setting is only altered if you ask at time of delivery Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #813414 3rd Feb 2020 5:56pm
ngins
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Corris Grey
thanks as always to this forum that got me back into my defender when the fob just packed it in and I presume the spare fob wasn't coded to the car - all back up and running now - PHEW! was a bit hot under the collar as the alarm blared away for a while there! However as an aside, is there any way to get it going with just the key if the fob dies again? I can obviously get into the car but is there any ignition key sequence or something you can use to disable the alarm and immobiliser if the fobs die as I have both original keys, or if they are dead is that, that? The main thing is that I am up and running again and I will make a note to change the key fob batteries more regularly having got stuck - although I am sure I'll forget/get lazy eventually so its good to have a plan B. Smile
Update - I searched a bit more Smile so it’s EKA - emergency Key access. I haven’t tried it yet. Sounds like it will be noisy!
Post #813750 5th Feb 2020 1:59pm
Geoff S
Resync Defender TD5 Remote after battery replacement
Bob
Thank you, new to the Defender and helped someone out by replacing battery in remote Fob. Didn’t realise I needed to follow a procedure until it didn’t work after. This processs worked and 2005 90 TD5 working again. Many thanks !!!
Post #975932 29th Dec 2022 12:13am
