Home > Maintenance & Modifications > Waterproofing sealant choice |
Yorkshire90 Member Since: 22 Sep 2011 Location: West Yorkshire Posts: 193 |
Done a fair bit of searching on the forums before posting. Found a few brand names and sealants for decision.
Can see daylight through a few places on my defender hard top. The seal between the hard top and tub looks a bit worse for wear so going to give it a good seal all round, inside and out, even in the tub bottom... might as well. Will be looking for a black coloured sealant. Which would you buy out of these two I've found from this forum: Sikaflex 291 Fast Cure Marine Adhesive Sealant - BLACK www.ebay.co.uk/itm/Sikaflex-291-Fast-Cure-...317wt_1039 Or one of the Siroflex range super adhesive range SX MIGHTY STRENGTH MS POLYMER ADHESIVE & SEALANT www.siroflex.co.uk/sections/SXrange/MSadhesives_sealants.html Siroflex not far from my Grans for a shopping run too. Thanks for your thoughts. |
2nd Jul 2012 6:30pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Siroflex
Just had two tubes delivered to do the join between the HT and tub on the 90. Have a read. http://www.defender2.net/forum/topic12247.html?highlight=siroflex Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
2nd Jul 2012 6:41pm |
Hi James
That one is not mine just the thread I saw about the product and decided to try. PM the original poster as I am sure he will answer all your questions I purchased two tubes, it is a pain to find in black but probably easier to find in white. Edit - this is where I got mine from after lots of searching. http://www.transtools.co.uk/store/prod_830...white.html Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
2nd Jul 2012 6:58pm |
Can't comment on the Siroflex range as I have never used it. I can however not recommend highly enough Sikaflex. It is used prolifically through the marine industry above and below the waterline. 'Marine' is for me the keyword in the sales pitch.....If it can withstand the rigours of a sea salt water environment it will more than sufficient for use on a Defender.
Try one brand, if it's rubbish strip off and try the other. I personally would start with the Sikaflex, I've used it lots on the Defender.... If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 2nd Jul 2012 7:23pm. Edited 1 time in total |
2nd Jul 2012 7:16pm |
Duh! Sorry
Cheers Bob! |
2nd Jul 2012 7:17pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5662 |
Done my joint of tub to hard top with sikaflex
Top job, and good stuff Andy |
2nd Jul 2012 7:18pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1760 |
Siroflex mighty strength is great. Widely available in Brighouse and Barnsley which is not too far from Casvegas. Alternatively have a ride over to Holmfirth and I'll do the job for you
2nd Jul 2012 7:19pm |
Thanks for the offer Us CasVegasites aren't usually allowed out of the cave. I've emailed Siroflex for nearest stockist I reckon both products will do a quality job. It's just which is the easiest to get a hold of. Thanks for your input everyone. |
2nd Jul 2012 10:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20292 |
I was waiting for the Sikaflex announcement ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
2nd Jul 2012 10:05pm |
Agh! Apologies K9F... I've been reading replies via email updates and totally missed out your comment. Sorry. I did notice that the Sikaflex is triple the price of the Siroflex... perhaps this is for a reason? Either way, ginjez job with the SX Mighty strength does look a pukka job. Tough one... It is something that you want to do once and hopefully forget. Especially when you're getting the headlining out too and giving everything a good once over... |
2nd Jul 2012 10:17pm |
If you have problems sourcing you favoured Siroflex 'pm' me and I may be able to 'acquire' the odd tube of the much superior and 'not necessarily triple the price' Sikaflex.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Jul 2012 5:02am |
