![]() | Home > For Sale & Wanted > Wanted - SVX Central grille and SVX gear lever |
I'm looking for the SVX front grille ( only the radiator central part) and the SVX gear lever (only the gearbox lever)..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Dgardel,
If you find a good deal on the gear lever let me know. At nearly £500 a shot the dealers can forget it! ![]() Treat every day as if it is your last....one day you will be right!! |
I was lucky for the transfer lever bought new on eBay tor 80 bucks...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Croytec do a gear knob and shortly transfer knob
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
The SVX ones are not good to use in winter your hand will almost stick to them and you will
need to wear gloves, in your case just on your right hand ! ![]() |
Heard they were producing one for the Puma based on an SVX one, they did indeed sell a new original SVX one on E-Bay some time ago (thought they may have used it as a pattern). But there's nowt about a Puma one on their website that I can find..... ![]() Treat every day as if it is your last....one day you will be right!! |
We have fitted a gear lever so they do exist
![]() I cannot remember how much the gear lever was - and we are a Croytec dealer ![]() |
Landyash Member Since: 06 Feb 2011 Location: Nottinghamshire Posts: 286 ![]() ![]() ![]() |
Double post
I have one that I might sell.
What's it worth? |
Nowhere near what the dealers are knocking them on for! 'PM' me a figure and we'll start from there. ![]() Treat every day as if it is your last....one day you will be right!! |
pm me the price.... the lever or the grill? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Dgardel,
No worries from me it's not the grille I'm after! ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
K9F, For now my priority is the grille (I have all the pieces for the SVX front but I miss the central grid), due to the extra costs, I leave you the availability of buy the lever from Ash (I just PM him about that). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
![]() ![]() ![]() How are you getting on Dgardel sourcing a grille? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Please!
help me to look for a SVX (or F&I or Rought) front grille (at a low/right price)!!! ![]() ![]() IID Pro MV License |
