Home > Puma (Tdci) > headlamp switch problem
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
anyone have one or have replaced one?
thanks for the advice---
John 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #152187 27th Jun 2012 11:41am
K9F
Here you go John,
May point you in the right direction.... Thumbs Up
http://www.defender2.net/forum/topic5649.html?highlight=burnt
http://www.defender2.net/forum/topic11186.html?highlight=solder If you go through life with your head in the sand....all people will see is an ar5e!!
Post #152188 27th Jun 2012 11:44am
Eduardo
me,
2 times: it is a easy work. Took 1 hour or less.
Appear to be a common fault (at least in mine).
Cheers Eduardo
Post #152192 27th Jun 2012 12:15pm
Merlin
Told it's a common fault, mine went after 2 years, just wouldn't turn on. Seemed locked solid.
Merlin
Post #152197 27th Jun 2012 12:33pm
mobilecentre
Common fault across all Defenders - switch often burns out.
Post #152199 27th Jun 2012 12:40pm
wouldn't it be great if a forum sponsor could supply a "relay upgrade" kit ?
I have a spare switch for just such an occasion, and indeed the contacts are housed on a soft/plastic sheet/backing. when they get warm, they melt and the contacts no longer make contact.
having said that, it's pretty easy to wire up a relay ... Thumbs Up
Post #152200 27th Jun 2012 1:18pm
mobilecentre
I agree - making a realy kit is simple and we have all the parts in stock. However it is the spec of the kit that makes it complicated.
A few examples would be
Tinned cable to resist corrosion?
Waterpoof relay holders and bases?
All these add cost then we tend to get blasted by people who can pick the parts up from Ebay for 15
Tim
Post #152201 27th Jun 2012 1:23pm
mobilecentre
Of course LED headlights draw half the power so are much less likely to cause switch failures Whistle
Post #152204 27th Jun 2012 1:25pm
and having seen the new sidelight models, they look fantastic too ... Thumbs Up
Post #152208 27th Jun 2012 1:38pm
K9F
They all look fantastic and the light they throw is too. I am only too well aware of the vulnerability of glass.... Whistle I saw the polycarbonate lenses at the B & W show and personally am glad I have the glass ones. It will be interesting to get feedback about the polycarbonate lenses from avid offroaders and from hotter climes to see how they stand up to the rigours of scratching, hot sun etc....I was wondering if the lenses may go opaque after a while? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #152244 27th Jun 2012 6:09pm
mobilecentre
Glass is the better material Thumbs Up
Post #152250 27th Jun 2012 6:24pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Mine burnt out (on a TD5), coupla minutes wiv a Pozidriv screwdriver, job done.
BUT, on my LHD Puma it looks as though some of the fixings on the underside of the steering wheel cowling are made inaccessible by the mini shelf underneath it.
I havent looked too closely, but when this switch burns out (note I didnt say if), is it necessary to remove this mini shelf to split the cowling - I couldnt see at first glance where it was fixed - and how fiddly is it?
Peter
Post #152331 27th Jun 2012 10:17pm
Birdy wrote:
BUT, on my LHD Puma .... Peter
Peter - do you have the same heat from the left and right sides of your heater ? I have LHD model too and there is a small difference .. did you have yours fixed ?
Post #152351 28th Jun 2012 6:39am
I made a loom for my 110 after the lights died on Salisbury plain one night.
I just used 2 relays, a plug from an old switch and a socket (for the same) that I had on an old dash loom.
It's prely plug & play, as the relays get their voltage from the main headlight feed anyway. the switch just turns the relays on (one for sidelights, one for main beam) and the relays do the switching.
With a bit of cable, about 6", there's enough slack to fit the relays behind the dash.
Post #152356 28th Jun 2012 6:51am
spudfan
Ireland
Anyone got a part number for the light switch? Lucas or LR. Is it the plug in or the flat spade type connecor?Might get a spare. Went on the tdi a few years back, interesting journey home using the hazard warning lights! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #152822 29th Jun 2012 11:25pm
