![]() | Home > Puma (Tdci) > headlamp switch problem |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4763 ![]() ![]() |
Thank you very much.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 883 ![]() ![]() ![]() |
BPman
Re LHD heater: checked out the heat coming from the dash vents, no discernible difference at any of the fan speeds. Summat wot actually works as it was intended! Peter |
must have fixed the issue on the 2011 models ![]() |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 619 ![]() ![]() ![]() |
Isn't the internet a fantastic thing...
Main beam failed this morning (sidelights still ok) - quick search on here and bingo I have the answer. Anyway that was the easy bit, tried to build up the contact with some solder, but managed to melt the plastic. Ended up drilling a small hole and using a self tapping screw to create a new contact. It's a bit of a hodge so ordered a new switch from defenderbits, but at least I can get to the station tomorrow morning. So thanks for the previous posters ![]() |
nomad Member Since: 04 Jan 2015 Location: bury st edmunds Posts: 9 ![]() ![]() |
hi all. checked out the switch, done the continuity thing seems ok, even tryed to bypass...still no joy tho? ordered new switch. any ideas please?
mpm Member Since: 28 Mar 2013 Location: Cheshire Posts: 8 ![]() ![]() ![]() |
Have u checked 4 voltage, could have blown a fuse ?
