Home > Td5 > Rubbish - Injector seals or cracked head.
Page 2 of 2 <12
excossack
Mine is a Jan 1999 model and the engine is a 10P 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #150984 18th Jun 2012 5:27pm
bob neville
That ties up John, 10P was used , I think, from the start of the TD5's up to the change to EU3 spec in 2001/2.
It is the 2001/2 registered vehicles that seem to have what was on the shelf when it was built Laughing
I would guess the more popular vehicles are likely to have the EU3 engines but this is Land Rover we are talking about here so anything is possible.
2013 Defender 90 CSW - sold
Post #150986 18th Jun 2012 5:34pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
15P - but still had plastic dowels Big Cry
Replacement engine being ordered tomorrow, fitted Thursday Friday this week then straight down to Bristol and West LR Show!
Doing the cluch and flywheel while I am at it.
Gonna be busy! 2002 Defender 110 DC
Post #150987 18th Jun 2012 5:34pm
bob neville
Interesting, all the research I have done shows the 15P's had steel dowels, obviously that is not correct. Maybe it was at some point in the 15P's run that they were changed.
Where are the experts when you need them ? Laughing
Post #150988 18th Jun 2012 5:38pm
ben_j85jty
That is one of the reasons I bought the truck, I figured getting the later one would mean less problems.
Ho Hum.
The car is a 52 Plate first registered 15/11/2002. Strangely just noticed my V5 says the truck has a revenue weight of 3500kgs - thouth they were 3050kgs? Oh well. 2002 Defender 110 DC
Post #150991 18th Jun 2012 5:43pm
bob neville
And this looks like the answer !
According to this mine has plastic dowels as well.
All td5 derivatives within VIN range
ds2 02 my 2A736340 - 3A793895
def 02 my 2A622424 - 3A647705
Cylinder head locating dowels.
Td5 engines fitted to vehicles within the above VIN range are fitted with
plastic dowels to locate the cylinder head onto the cylinder block.
LRE has intrduced steel locating dowels from the following VINs.
ds2 - 3A793895
def - 3A647705
IMPORTANT
If a cylinder head is removed from a vehicle in the above VIN range, the
plastic dowels must be replaced with new spec steel dowels, which are now
available from LR parts.
CAUTION
TD5's prior to the above VIN ranges must not under any circumstances, be
fitted with the new steel dowels.
If steel dowels are fitted to earlier engines cylinder head cracking may result!
Post #150995 18th Jun 2012 5:50pm
ben_j85jty
Boll0X
My VIN - 3AXX7177
Less that 600 Engines out - Thats probably a week of production...?
Big Cry Big Cry Big Cry 2002 Defender 110 DC
Post #150997 18th Jun 2012 5:53pm
I wonder if the holes for the steel dowels (on the later engines) are just slightly bigger than the holes for the plastic ones?
Wonder if the earlier heads can just be drilled out slightly to accomodate the stronger dowels? (i'm assuming the steel dowel expands when hot more than the ali head does, hence the cracking)
Post #150999 18th Jun 2012 5:55pm
bob neville
That is unlucky, I guess it is 2003MY that has steel.
Post #151001 18th Jun 2012 5:57pm
ben_j85jty
Mine local indy replaed the plastic with metal, but has them specially made to fit into the plastic holes.
When I get the engine back I will be stripping it to see what has happened. If it turns out their dowels have caused this I may just be tempted to kick up a real fuss. 2002 Defender 110 DC
Post #151002 18th Jun 2012 5:57pm
T1G UP
i don't see the head moving causing the injectors to leak.
head gasket issues yes. The 10p engines suffer because of the flow and return internal chamber for the fuel. the 15p have an external return pipe and thicker walls on the flow.
get it done and get one with it. give it a good run, get it nice and warm.
Post #151004 18th Jun 2012 6:00pm
wslr
Exactly, usually down to a crack adjacent to one of the injectors. Has anyone been in there removing the injectors in the past? Perhaps they didn't follow the fitting/removal guidelines? Not always the cause though.
Post #151013 18th Jun 2012 6:50pm
ben_j85jty
The head gasket went due to the head moving about 8k ago.
The head was pressure tested then and had to be skimmed, so the injectors were taken out then. I am guessing the combination of all these things has caused the failure, I will be keeping the engine and haveing a good look at it as time allows, I have never venture too far into an engine so should be a learning experiance. 2002 Defender 110 DC
Post #151020 18th Jun 2012 7:07pm
wslr
The Td5 is pretty easy.
It is worth getting the head crack tested and not just pressure tested. I send ours off to an engineers miles away from us, simply be cause they perform both services.
Post #151021 18th Jun 2012 7:10pm
Page 2 of 2 <12
