Home > Td5 > Rubbish - Injector seals or cracked head. |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
The 110 decided to start dumping oil last night.
I have no time to look at it so took it to our local independant who confirmed my fears. Will know on Friday after they fit new seals and run it up. 2002 Defender 110 DC |
30th May 2012 5:27pm |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Good luck with the seals ..... hopefully that will be all.
Glyn |
30th May 2012 5:35pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5695 |
Fingers crossed for you, I know it's not a good time for it to happen
Andy |
30th May 2012 7:48pm |
Yes, Bad timing really. Still, can't be helped. Just trying to work out how to get my gear to the ALRC Nationals this weekend! 2002 Defender 110 DC |
30th May 2012 8:02pm |
Well, a bit of an update -
Had the injector seals replaced and put a tank full of diesl through it - to find half the diesl in the sump Now working out options - Recon head, Low Mileage Engine, New truck? Arrgggggggghhhhhhhhhhh 2002 Defender 110 DC |
17th Jun 2012 7:47pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
new head...the later spanish ones are about 1500.
or a s/h engine. or a quick PX for a puma? |
17th Jun 2012 7:48pm |
Those seem to be the options.
New head is £1500 Plus fitting Low Mileage TD5 - £1350 plus fitting (and I would do the Clutch while I was at it ) PX for a 110 USW......££££££££££ 2002 Defender 110 DC |
17th Jun 2012 7:52pm |
well your up the river without a paddle! So if moneys tight fix it and sell it, then get another later. I'd go head if the miles where sensible although i bought a s/h engine for my old td5 and changed it myself. a puma ££££ more but you can work it into the dealer. |
17th Jun 2012 7:59pm |
I had figured about the same for a Turners one.
Seems to be a few on eBay with 12month warrenties for a little less, Circa £800 taking that bill down a little. Leaning toward engine change to be honest. Not a guarenteed to be a complete fix but Ithink the odds are better. 2002 Defender 110 DC |
17th Jun 2012 8:24pm |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 |
What actually happened and how many miles has the motor done? 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy |
18th Jun 2012 5:04am |
2 weeks ago SWMBO came home in the 110 and I noticed oil splattered all up the back.
On close inspection it turned out to be a leak from the turbo pick up, so before I drove it to the local indy to put a new seal on (I was flat out at work so no time to do it myself) I checked the oil. Despite the large amount up the back an along the chassis the level had gone up. Local Indy drained the oil, changed the injector seals ran it for a few miles and released it saying it might be fixed, keep checking the levels. One 160 mile journey later mad the levels have risen again, causing me to get a yellow AA taxi home - not wanting to risk the engine any further. There we are. Injector seals change and sump still filling with oils leads me to the conclusion of cracked head. The engine has done 130k 2002 Defender 110 DC |
18th Jun 2012 6:45am |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 |
Sorry to hear that mate, thought the cracked head thing was more of an issue on the early ones, take it they were genuine Land Rover seals fitted so its not a duff seal causing it again. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
18th Jun 2012 10:34am |
Mine is an Early - late model if tht makes sense? I both this one as it was post 2002 thinking the issues would be sorted, however the engine appears to be old stock, it ha the plastic dowels for example. 2002 Defender 110 DC
18th Jun 2012 12:00pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
What are the first 3 digits of your engine number ?
10P is the EU2 used up to 2001/2 and 15P is the 2002 EU3. As far as I am aware the 10P engines were the ones with the pastic head dowels and the ones with the most problems. Mine is a 2001 but 2002 MY and has a 15P engine fitted. It is a September 2001 registered vehicle. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
18th Jun 2012 5:20pm |
