![]() | Home > Puma (Tdci) > Repeated high temp and failure |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
No idea as such but if the dealers have checked everything I would look at the ECU and reload the software just in case it has a fault afterall computers are not always perfect BM52
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Have a look at LR TECHNICAL SERVICE BULLETIN No.LTB00300/2010, 08 July 2010
Highlights of tech bulletin: Check continuity of inline fuse P110, located under the RH front seat . If the fuse has failed, replace as necessary and check related wiring circuit for any signs of a potential cause, paying particular attention to the harness route around the red colored engine lifting eye at rear of engine and the area around the exhaust gas re-circulation valve for signs of abrasion. Also check the integrity of the under bonnet earth points located on and around the bulkhead. Check for correct operation of the main relay located under RH front seat. In addition look for any signs of arcing or loose terminal connections to the relay. There was a batch of faulty PCM modules fitted to Defenders pre 14th October 2009. The only way to check if your friend has one of the faulty PCM's is to read the 4/5 digit number on the top right corner of the PCM. For example 9D98 would translate to 9/4/09. 1. Year 8 =2008/9 =2009/0 =2010. 2. Month C =March/ D =April/ F =June. 3. 044 = Day 44/ 98 =Day 98/304 = Day 304. This would put the PCM into, the might be faulty bracket? Brian. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2467 ![]() ![]() ![]() |
cheers! many thanks. Puma 110" SW
