Home > Puma (Tdci) > Not so bad................ |
..........for a standard setup and antiroll bars fitted.........
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Sep 2009 8:49am |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
Looking good, but get it on an axle twister and it will go a fair bit more
Glyn |
1st Sep 2009 9:19am |
Yes, a little fork lift
1st Sep 2009 2:52pm |
I spend the 70% on road, so, I prefer the antiroll set up..... |
1st Sep 2009 5:31pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
I think he means you have more articulation to go there Mike |
1st Sep 2009 6:04pm |
Yep . I also have anti roll bars (don't think I could live without them now). But if you got another set of forks on your rear right wheel, and do the same you will find out you still have probably another few inches lift As you can see here, mine is on std springs and a/roll bars but if you get t right you can see that the wheels making contact are right up into the arches and the ones with no weight on drop down lower . On this day out I had 2 wheels off the ground at the same time (TC took over ) Glyn Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Sep 2009 6:14pm |
Oh mate, now I have understood...
1st Sep 2009 7:56pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
This is my previous 110 and was on std shocks - ome +40mm springs - front anti roll bar
Click image to enlarge |
1st Sep 2009 10:17pm |
