Home > Puma (Tdci) > oil spray
Grockle
oil spray
seems to be coming from the steel pipe flange on the l/h side of the engine any ideas folks ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #148541 4th Jun 2012 10:51am
dgardel
Italy
Re: oil spray
any photos? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #148556 4th Jun 2012 11:57am
Grockle
no sorry dg,it's the large stainlees steel pipe about 6 cm in dia 2.4 90 XS
Post #148557 4th Jun 2012 11:59am
Glynparry25
Re: oil spray
dgardel wrote:
any photos?
I second that. When you say left hand side.... do you mean left hand side as you look at it from the front or from the drivers position?
Only 'Oil spray' I have come across with this engine is the old vacuum pump problem: http://www.defender2.net/forum/topic585.ht...accum+pump
Oil sprays out of the seal on the right hand side of the engine (as you look from the front of the vehicle).
Glyn Dog Sheep
Post #148558 4th Jun 2012 12:04pm
defninety
1985 Defender 90 Td5 XS CSW Bonatti Grey
If you're talking left hand side as sitting inside the vehicle then the only stainless steel pipe I can remember is the EGR pipe. This has the smaller transfer pipe entering the side of it and has the MAP sensor located on the top of it. Is it this one?
Post #148562 4th Jun 2012 12:13pm
Glynparry25
Is this what you are talking about:
If so, the S/S pipe is the inlet so shouldn't be spraying anything, but the pump on the left of the picture is the vacuum pump which causes problems...... It does spray EVERYWHERE!!
*EDIT*.... If it is coming from that inlet pipe, it means the turbo has more than likely blown its seals, which means you will need a new turbo. All the pipes and intercooler will need cleaning out and all leaks (like the one at the flange joint) will need inspecting and repaired.
If it is the vacuum pump- it is about £100 for the pump and seal and you can repair it yourself in about 30 mins to an hour.
Glyn Dog :sheep:
Post #148563 4th Jun 2012 12:14pm
dgardel
Italy
Should be a normal if you have the inlet screws (form SS pipe to the plastic manifold) looses or the o-ring seal damaged.
The inlet manifold is normally "wet" of oil and it camping from the oil vapor closed circuit...... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #148566 4th Jun 2012 12:25pm
Glynparry25
I agree with that.... But for it be be 'normal' it would take a very long time to notice it. We are talking about a max of about 500ml over about 20,000 miles. By the sound of things.... or my definition of 'spraying' is you can see oil not only on the joint but also on items around it?....... Picture would make it sooooo much easier, lol.
Glyn Dog Sheep
Post #148567 4th Jun 2012 12:34pm
Grockle
Glyn Dog Sheep
Thanks Glyn,
I had the vac pump changed last year pos oil from that will keep an eye on it
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2.4 90 XS
Post #148568 4th Jun 2012 12:44pm
zuluphil
South Africa 2009 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
In January 2010 I took delivery of a new defender 110 SVX at full price(since found out built in 2008) and after just 9233 kms the brake vacuum pump burst spraying oil all over engine bay and reducing braking efficiency,it had had the first two services with the next one due at 24000kms or 6 months,I have since found out that the vehicle when sold to Me had a faulty brake vacuum pump and Land Rover had sent out Four bulletins directing dealers to replace the pump when requested,I was very surprised when I was told that they would not repair free of charge as I had missed my next service,I admitted to missing the service but as it was a safety issue with only 9000 kms on the clock AND i had bought a Disco 3 HSE and a Disco 4 HSE from them maybe they would do it as a "goodwill" gesture,with a straight face they said NO! Am I unreasonable Whistle
Post #156530 18th Jul 2012 6:00pm
spudfan
Ireland
I do not think you are being unreasonable, as the brake vacuum pump has nothing to do with the scheduled servicing. This was (is?) a known issue and the fact that Land Rover issued four bulletins about it speaks for itself. Either try the Land Rover customer services route or phone another dealer and ask if they will do it as it was not done when it should have been done. It is a bit short sighted of the dealer not to accomodate you considering all of the business you have given them.
People here have changed this themselves so if you want to go down that route there will be no shortage of advice - or skint knuckles!
Good luck. Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #156577 18th Jul 2012 8:05pm
Glynparry25
As Spudfan says^^^^^^^^^^^^^^^^
On the other side..... I took 30 mins exchange mine due to incompetent dealer (limassol, Cyprus)
Glyn Dog Sheep
Post #156587 18th Jul 2012 8:23pm
