Home > Puma (Tdci) > LED lights |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I like the clear ...
Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Go Beyond on 30th May 2012 12:44pm. Edited 2 times in total |
30th May 2012 12:31pm |
Clear is ok if you're a teenager....
30th May 2012 12:32pm |
Or you are a grown up with an SVX .... |
30th May 2012 12:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Sorry but Go Beyond is right the clear is ace. And no I am not a teenager.. I know one what is though que Killer90 The only thing is with the LED I personally don't like is that they are a bit round and wide / flat for my liking so look a bit bug eye'd. I really like the clear originals too. So long as all of it is done for example not clear indicators on the rear but the rest i.e. brake lights are original. That really does look silly
30th May 2012 12:43pm |
Mobile Centre do a range of the smaller 70mm LED's as well - mine above are 95mm ....
30th May 2012 12:45pm |
That's good to know. I'm not saying they look bad just that they look a bit larger. Good for brightness no doubt though |
30th May 2012 12:47pm |
Each to their own, if we all liked the same thing it would be a boring world
30th May 2012 12:49pm |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Mine. All original clear LE Perei and all with LED's in apart from the indicators:
Click image to enlarge Pete |
30th May 2012 12:59pm |
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 |
Click image to enlarge Stu |
30th May 2012 1:52pm |
Stu's ones look like the 70mm Mobile Centre ones ...
30th May 2012 1:54pm |
Sure would. One reason I had a Defender in the first place a bit different not a run around |
30th May 2012 2:33pm |
Yep, got them front and rear in clear. Works well on black bodywork, not so sure on other colours. Stu |
30th May 2012 3:05pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
For the rear you have the choice of 95mm or 70mm.
OE size is 70mm and there is no difference in brightness between the 70 & 95mm LEDs Front is only really 70mm due to the lack of a front position light in 95mm LED. Choice of clear or coloured in both 70mm & 95mm See here for our brochure http://www.defender2.net/forum/topic12881.html Tim |
30th May 2012 3:52pm |
