Home > Puma (Tdci) > LED lights
Page 3 of 3 <123
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Not a good picture, but like i said i bought (on ebay) Wipac clear lenses for all the front and rear lights and then purchased 380 1157 LED bulbs. For the brake lights i did however have to use the original connector as the one for the side indicators wasn't the right connection, but all i did was put the bulb in the original connector and it fit straight in the Wipac Clear Lense.
Will get a better Picture when dark if possible :wink:
Post #147860 31st May 2012 7:47am
mobilecentre wrote:
leeds wrote:
Just a word of caution, if you have LED in your indicators and tow a lot the trailer indicator lamp on your dash will not flash correctly.
Not unless Tim knows a way around that small issue.
Brendan
A number of choices to get round this
Thumbs Up
Post #147863 31st May 2012 8:04am
Will get a better Picture when dark if possible Wink
My only concern with the LED bulbs is the brighness and the directional output. Unless they are different to the reversing light one have it's very directional. Annoying how for some reason a normal light bulb in my reversing light won't work but and LED will :?
Post #147874 31st May 2012 9:19am
dgardel
Italy
Pay a lot of attention about the LED bulbs, there are same model where, for a strange current return internal of the bulb) that make the Defender crazy (eg, side light + push the brakes = the cockpit goes ON Shocked Shocked )....
Better to spend the right money and have a complete working (and right ECE homologated) solution..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #147917 31st May 2012 12:45pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Brendan
Spill the beans then Tim.
Pete
Post #148032 31st May 2012 10:04pm
mobilecentre
The most basic fix is to splice a resistor into the indicator circuit each time you change a bulb, so if you replaced your indicators front and rear that would be four resistors. These work by acting as dummy loads and creating a load on the circuit similar to that of the original bulb and dumping this as heat. They need mounting to metal work as they get very hot but this will retain the original relay & functionality.
The next least expensive is to fit a towing buzzer on the electrics at the rear
Then we get onto electronic solutions that we have developed but because of the market preferring resistors - such as those Wipac supply with their 95mm lamps in order to keep the headline price low then we do not push our electronic solutions as many feel the lights are already overpriced Embarassed
Post #148050 1st Jun 2012 7:56am
XS Pete
Oh thanks Tim. So you only have work arounds too. I thought you were going to say that you had a proper plug in replacement relay solution to address this issue.
Pete
Post #148370 3rd Jun 2012 7:02am
Tbh I tow with both the Defner and Vito both don't have trailer dash lights as such and its never worried me
I check them at hitch up and mid journey if it's a long one
Just my thoughts
Post #148376 3rd Jun 2012 8:16am
mobilecentre
Pete
Hi Pete
As I said we then move onto electronic solutions which we have a plug & play relay based solution that will give trailer monitoring with LEDs but cost wise is more money than a set of lights as the demand is not there.
Tim
Post #148384 3rd Jun 2012 9:21am
Page 3 of 3 <123
