Home > Td5 > 2006 TD5 won't turn over -- Any Help
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Hi,
Now yesterday it was fine & no hint of any battery/Startrer issues. It has so far started every time first time, even after 4 weeks without use!
This morning I jumped in, went to start it, lights on dash came on, waited for glow plug light to go out & then turned key!! Nothing. Not even a click!
The fuel pump is priming, just nothing from position II to III!
I though the battery may be the issue so I charged that today, then this evening! Nothing! Same issue.
I put multimeter across battery & it's showing 12.6, drops to 12.3 when I turn to position III
I noticed the immobiliser light rapidly blinking when I lock it, so I swapped the battery on the fob, No change. I tried the spare, Nothing
Any other things I should check?
TIA 2006 Defender Double Cab- Zambezi Silver
Post #147381 28th May 2012 5:33pm
TD5_dan
2001 Defender 110 Td5 CSW Java Black
Well my immobiliser light blinks very fast for a while after the vehicle has been locked so wouldnt worry about that, just check it isnt blinking rapidly when trying to start it. Well if you are sure the battery is good and you have all dash lights then you want to be checking you have a trigger voltage down at the starter motor if you have then its not immobiliser related and therefore it is likely to be a problem with the starter motor solenoid. Check all your terminals on starter and earths etc. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon
1970 Series 2A hard top
1960 Series 2
1972 Series 3
Post #147389 28th May 2012 5:50pm
airpusher
Cheers,
Embarassed Embarassed Now silly question alert!! Were is the starter motor located in the engine bay? Embarassed Embarassed Embarassed
No, when I try to start it, the immobiliser light is out! But there is a resounding silence. I did notice the stereo lights go out. So perhaps it is the battery! I've put it on charge & I'll see tomorrow.
It seems to have happened so quick though, no problems at all before. It had a long run up to Pembrokeshire over the weekend too.
mmmm 2006 Defender Double Cab- Zambezi Silver
Post #147407 28th May 2012 6:44pm
JWL
Off the top of my head there is a starter relay behind the fuse box in front of the gearsticks, have you tried to see if there is any power to the starter motor situated on the RHS rear, look under the brake servo. When you turn the key to start the relay should click.
Post #147413 28th May 2012 6:52pm
airpusher
I've just put the battery on charge in the garage.
I'll have a look at the when I put t back in tomorrow.
Cheer again 2006 Defender Double Cab- Zambezi Silver
Post #147415 28th May 2012 6:58pm
Romadog
Check small power wire to solenoid on starter motor. Disconnect and re connect. This may be enough to clean the contacts.
I had this problem outside my village shop when I called in before arriving home. Paid for goods, came outside to Land Rover and it did just what you described. I had the drivers seat up checking main fuses etc, but still nothing. Called Land Rover Assisstance, along came Green Flag man and he just walk up, opened bonnet, stretched in and then said..'now try it'. And she started. Apparently its a common problem.
Well I had the same on my V8 Disco a year later .
Post #147420 28th May 2012 7:11pm
robpenrose
Is the battery in the key fob ok?
I was told it needs it to start the vehicle, and the fob has to be in range, so if the battery has gone, it can prevent the car starting. Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #147451 28th May 2012 9:48pm
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Try turning on the ignition, run a wire from the main feed on the starter motor to the small wire of the solenoid (bridging it out). Hopefully it should start turning over.
Post #147452 28th May 2012 10:09pm
SimonDavies
Edit: double post.
Post #147453 28th May 2012 10:12pm
JSG
Check the relays under the drivers seat, it will be the starter relay worked loose Thumbs Up John
2011 Tdci 110 CSW XS
Post #147461 28th May 2012 11:15pm
Have a word with DEF-00 - he'll turn it over for you Thumbs Up
Post #147467 29th May 2012 6:09am
airpusher
Thanks for all the help guys,
It turns out it was the small wire to the solenoid!!!! Crazy, I did what Romadog suggested & it sprang into life like usual!
Crazy that such a small inconspicuous wire can cause such issues!
Oh well, I knw what to check if it happens again!
Thanks again, so much much help available on here.
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up 2006 Defender Double Cab- Zambezi Silver
Post #147484 29th May 2012 8:18am
petethediver
Spain 1999 Defender 110 Td5 CSW Galway Green
Just read this post,landy died this morning,went and wigled the small wire on the solonoid,bingo!!!!!!,thanks mate.
Post #292439 22nd Dec 2013 4:39pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
The copper contacts in the starter is on its way out. So when you turn the key, the solinoid energizes to throw the pin to the copper contacts. When worn, the pin does not make contact. So no sound. You can try turning off n on n cranking till it can contact, tap the starter with a mallet n it should be ok. I had these symptom n after removing cleaning the relay wire n having this no start situation in the strangest situation, I had the starter rebuild n all was good. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #292596 23rd Dec 2013 2:09am
