![]() | Home > Td5 > 2006 TD5 won't turn over -- Any Help |
TD5_dan Member Since: 24 Feb 2012 Location: Essex Posts: 449 ![]() ![]() |
Well my immobiliser light blinks very fast for a while after the vehicle has been locked so wouldnt worry about that, just check it isnt blinking rapidly when trying to start it. Well if you are sure the battery is good and you have all dash lights then you want to be checking you have a trigger voltage down at the starter motor if you have then its not immobiliser related and therefore it is likely to be a problem with the starter motor solenoid. Check all your terminals on starter and earths etc. 2001 TD5 110 County Station Wagon - sold
1970 Series 2A Station Wagon 1970 Series 2A hard top 1960 Series 2 1972 Series 3 |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 372 ![]() ![]() ![]() |
Cheers,
![]() ![]() ![]() ![]() ![]() No, when I try to start it, the immobiliser light is out! But there is a resounding silence. I did notice the stereo lights go out. So perhaps it is the battery! I've put it on charge & I'll see tomorrow. It seems to have happened so quick though, no problems at all before. It had a long run up to Pembrokeshire over the weekend too. mmmm 2006 Defender Double Cab- Zambezi Silver |
Off the top of my head there is a starter relay behind the fuse box in front of the gearsticks, have you tried to see if there is any power to the starter motor situated on the RHS rear, look under the brake servo. When you turn the key to start the relay should click.
I've just put the battery on charge in the garage. I'll have a look at the when I put t back in tomorrow. Cheer again 2006 Defender Double Cab- Zambezi Silver |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1750 ![]() |
Check small power wire to solenoid on starter motor. Disconnect and re connect. This may be enough to clean the contacts.
I had this problem outside my village shop when I called in before arriving home. Paid for goods, came outside to Land Rover and it did just what you described. I had the drivers seat up checking main fuses etc, but still nothing. Called Land Rover Assisstance, along came Green Flag man and he just walk up, opened bonnet, stretched in and then said..'now try it'. And she started. Apparently its a common problem. Well I had the same on my V8 Disco a year later . |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 ![]() ![]() |
Is the battery in the key fob ok?
I was told it needs it to start the vehicle, and the fob has to be in range, so if the battery has gone, it can prevent the car starting. Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 ![]() ![]() ![]() |
Try turning on the ignition, run a wire from the main feed on the starter motor to the small wire of the solenoid (bridging it out). Hopefully it should start turning over.
Edit: double post.
Check the relays under the drivers seat, it will be the starter relay worked loose
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Have a word with DEF-00 - he'll turn it over for you
Thanks for all the help guys,
It turns out it was the small wire to the solenoid!!!! Crazy, I did what Romadog suggested & it sprang into life like usual! Crazy that such a small inconspicuous wire can cause such issues! Oh well, I knw what to check if it happens again! Thanks again, so much much help available on here. ![]() ![]() ![]() ![]() ![]() ![]() |
petethediver Member Since: 22 Dec 2013 Location: Gerona Posts: 1 ![]() ![]() ![]() |
Just read this post,landy died this morning,went and wigled the small wire on the solonoid,bingo!!!!!!,thanks mate. |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
The copper contacts in the starter is on its way out. So when you turn the key, the solinoid energizes to throw the pin to the copper contacts. When worn, the pin does not make contact. So no sound. You can try turning off n on n cranking till it can contact, tap the starter with a mallet n it should be ok. I had these symptom n after removing cleaning the relay wire n having this no start situation in the strangest situation, I had the starter rebuild n all was good. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
