Home > Puma (Tdci) > 2.2 or 2.4 ? and other questions
Page 3 of 4 <1234>
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
jerseyman wrote:
the salesman also offered my £4,000 Part-ex for my 2001 TD5 90 Tomb Raider with 26k miles on the clock .... mmm tempting
Is that sarcasm? I would have thought it's worth more like twice that, especially with such a low mileage! E.g. I just sold a farmer-spec MY2000 Td5 90 for more than that.... with 118k on the clock. And I let it go quite cheap.
I'd have thought for a special edition like that, with those miles, £10k wouldn't be out of the question.
Post #98347 5th Nov 2011 10:31pm
jerseyman
Yes it was sarcasm - one of the problems with E Mail, we need a sarcasm Icon javascript:emoticon('Smile')
The last TR i saw on Ebay sold for £11.5k that had nearly 60k miles on it but was very cheap. Have a look here (stock number 615) for one sold last week for over £15k
To partially answer the other post, my TD5 is a nice vehicle, completely fault free in the 5 years I have had it, rock solid chassis, excellent interior, The only issue it has is a bit of the electrolysis corrosion that seems to bedevil TR's.
The interest in changing relates primarily in its proposed use to commute to Spain a couple of times a year so I would like a bit more refinement.
The comments about the gear change are a bit worrying the "there must be a gear here somewhere" box on the TD5 is a bit of an issue for my wife. Though I know a lot of it is finesse, my co-driver on my last trip had no issues with the gear change.
Post #98357 6th Nov 2011 12:13am
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Just to add to our kb - the major reason for the shift towards the 2.2l engine appears to be Ford abandons the 2.4l engine completely. If you look for the press releases last Birmingham you see that Ford is changing all Transit to the 2.2l engine to meet Euro5 regulations. When I asked directly I was given the "no more 2.4l engines, because it is pretty tricky to get these machines to EU5 and ones enough" ... Never forget: cars have owner, Landrover have field service personnel.
Post #98405 6th Nov 2011 11:29am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
bit off topic or not but...
after reading all this thread I'm still confused... I'm having a little discussion with some friends regarding the engine origin of the actual Defender (MY2011)...
It is correct that the engine is still from Ford and not PSA? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #146829 24th May 2012 8:42am
Yes, the Puma engine is a Ford, whatever the capacity. Darren
Post #146836 24th May 2012 9:14am
lrmaniac
can you, or anyone else, point me to an article, tech file to confirm this...I have a friend that showed me an article from portuguese autopress saying that the engine is the same as the freelander, from PSA...
I believe you all more than our auto press! Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #146920 24th May 2012 7:11pm
noworries4x4
Right then, oars in the water time, i have been running the new 2.2 now for 5 weeks and compared to the 2.4 its rubbish !!! Land Rover says same power and Torque figures No worries says my arse is it !!!
My simple test bottom of Telegraph Hill (A380 Devon) drop the 2.4 into 5th and its still doing 70 round the corner at the top. The 2.2 faster at the botton only doing 50/55 and realy wanting 4th on the bend at the top.
Towing the ifor i always seem to be dropping into 5th and seam to have my foot flat on the floor all the time.
Fuel consumption is currently 2mpg worse all conditions and if anything i am driving it more angenicly trying to make it better.
Had the dpf warning light on yesterday after doing 3Hrs across london escorting a crane at walking pace in low range. a good thrash round the North Circular sorted that out. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #146926 24th May 2012 8:07pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
as i have both the new 2.2 and the 2.4 i can give anybody the advice that there is no difference in power. The 6th gear is much faster on the 2.2 and it's quieter.
i have done 80.000 on the 2.4 and 7000 on the 2.2 both work very well never had any problems.
will need more time to know how the DPF filter will make any problems with time maybe a trip to australia next year will give me more information when it gets REAL rough and very hot.
but generaly impression is good. Very Happy LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #146928 24th May 2012 8:11pm
Well, the 2.2 in the Freelander is 2179cc whereas the 2.2 in the Defender is 2184cc, but if you really want the full story then have a read of THIS WIKIPEDIA PAGE. The situation is confused slightly by the fact that Ford also had a hand in the PSA engine, but as that page explains, it is a completely different unit. Hope that helps. Darren
Post #146931 24th May 2012 8:21pm
RobKeay
My mpg has gone down by 3 and my 2.4 was a 110. I've been towing alot and find it goes if you give it the beans. I do seem to be looking back thinking the td5 pulled a load better. I think it's the gearbox on the pumas that makes them. I have a feeling they would be awful mated to a r380. Now a td5 mated to a six speed I wonder could this be any good.
Maybe I should save up and bang a 3.2 in the 90.
Post #146936 24th May 2012 8:43pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
you have put doubt in my mind about the deposit i have put down on my new 2.2 130...... Crying or Very sad
Post #146946 24th May 2012 9:35pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
“I do seem to be looking back thinking the td5 pulled a load better”
Absolutely… I tow, launch and recover a quite heavy boat, and boy do I miss the TD5’s indifference to gear and gradiant.
Every time I pull away from lights and have to change gear almost immediately I’m listening for the crash of a car behind ploughing into the back of me. I only got rid of my TD5 ’cos of chassis rot, should’ve gone the galvanised chassis rebuild route.
And the 26 m.p.g. I’m getting is worse than my old TD5, also down to the ’orrible gearbox imho.
Peter
Post #146958 25th May 2012 12:01am
I suspect that I am in the minority with this view, but if I compare my 2007 Puma Defender clutch and gearbox with my 2002 TD5 Discovery clutch and gearbox the Defender is far, far nicer to drive.
The Disco (which I bought new) has always had a vague and extremely baulky change. 1st to 2nd is pants, it has to be rushed when cold (no double-declutching) and double-declutched and taken slowly when warm. 5th to 4th involves no perceptible sideways movement of the lever making 5th to 3rd changes strange. The clutch has always been dire as well and very susceptible to judder (despite having a new flywheel and clutch at 130k miles when the judder became intolerable, even though there was next to no wear on the driven plate). OK, this is a harsh assessment, but the clutch and gearbox are simply not as good as they should be on a vehicle of this type. It the near future I hope to fit a single mass flywheel to see if that improves the awful clutch.
The Puma clutch and box undeniably have their problems and it took me a while to get them right (new clutch, new flow restrictor, and removal of all backlash from the driveline) but compared to the Disco is it a more precise change, lighter, and the clutch has more feel and prgression, and overall is much nicer to operate. If the TD5 was as good as the Puma I would be a happy man.
I think a lot of people who are used to cars and car-like behaviour get on better with the engine characteristics and gear ratios of the TD5 than the Puma, whilst those who are used to HGVs have no trouble with the torque characteristics and ratios of the Puma; the Puma is very different but is imho ideally suited to its job as a working (load carrying, towing) vehicle. I rate the 2.4 Puma Defender as the best of many Landrover Defender-type vehicles I have owned and driven over the years and would certainly opt for a 2.4 Puma over a TD5 anyday. Would the Puma engine work in a Discovery? Definitely not, but Defender yes, very well.
Just my view.
Post #147009 25th May 2012 11:00am
twopoint6khz
Td5 gearboxes are a bit of a mixed bag I think - I've had two and they both feel completely different Confused The current one is worse by a long way, 5th gear is pretty vague to get into and 1st to 2nd requires some serious tapdancing. I also seem to 'beat the synchro' a lot more than in my old one and get the feeling of grinding cogs through the stick.
Hoping some proper gearbox oil will sort it out.
Post #147012 25th May 2012 11:08am
chadjizz
blackwolf, i agree, i find my 2.4 puma gearing perfect for pulling - hill starts with a 1.5t digger on the back is easy as pie!
Post #147029 25th May 2012 12:25pm
Page 3 of 4 <1234>
