Home > Technical > puma starter motor problem |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
If its a year 2000 model then it's a td5 not a puma
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
23rd May 2012 7:01pm |
ficauto Member Since: 07 Nov 2011 Location: FALKLAND ISLANDS Posts: 5 |
hi steve
thanks for pointing that out pressed wrong key simon |
23rd May 2012 7:16pm |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
Sounds to be an electrical command problem rather than the Starter Motor itself.
Check the engine wiring loom that runs across the rear of the engine, make sure it's not damaged through contact with the red engine lifting bracket (if fitted), this is a common problem and would give you this kind of fault. Richard Either a 90, 110 or 130. Discovery 5 |
24th May 2012 8:42am |
