Home > Technical > puma starter motor problem
ficauto
Falkland Islands
hi
i have a problem with a puma 2010 model
i had the startor motor changed and ignition switch changed due to the startor motor engaging it self, this seemed to solve the problem
however the problem has come back the starter motor is engaging it self again, this was only changed 3000miles ago
i have had it on SDD and there are no faults stored
has anyone got and ideas what is causing this
simon
Post #146733 23rd May 2012 6:50pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
If its a year 2000 model then it's a td5 not a puma
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #146739 23rd May 2012 7:01pm
ficauto
Falkland Islands
puma starer motor problem
hi steve
thanks for pointing that out pressed wrong key
simon
Post #146746 23rd May 2012 7:16pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Sounds to be an electrical command problem rather than the Starter Motor itself.
Check the engine wiring loom that runs across the rear of the engine, make sure it's not damaged through contact with the red engine lifting bracket (if fitted), this is a common problem and would give you this kind of fault. Richard
Either a 90, 110 or 130.
Discovery 5
Post #146830 24th May 2012 8:42am
