Home > For Sale & Wanted > FREE Cargo barrier but might not be ex-Defender. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Jon, As you say think it must be Defender one as measurements are correct. I've just measured and looked how the top part would fit in a TDCi, on the older models some are fixed to the ceiling in the middle but you could tie /bolt the top via the grab handles. I suspect it was designed to just push up against the roof whilst being bolted on the seat box - measurements of the lower bracket width height might be handy to see if they fit the seat boxes.
I'd take it for a donation but I'm too far away to justify a trip at the moment. Hopefully someone will use it, if it doesn't go let me know but I'm not sure when I'm up your way next. |
23rd May 2012 7:00am |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Hi Chris, have added the additional dimensions to the original post that should give you a better idea.
I'm reasonably keen to get it shifted, more so because I'm in a clearing out sort of mood rather than it taking up space. Jon - 110 td5 [sold]. Currently Defenderless. |
23rd May 2012 7:30am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Chris if you want it I can pickit up and hang on to it for a while if that helps? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
23rd May 2012 10:50am |
Thanks for the offer John , I'm in two minds at the moment having thought about storage this morning, so if anyone wants it go for it. Just thinking I need to re-jig the storage and I also put the back seat up regularly to get the boat engine in so don't think a one piece would be practical, need to maybe put in a roof shelf, take other rear seat out etc
23rd May 2012 11:33am |
If that's for a Defender then it's a very strange size. Width across the body at the waistline is around 1400mm and the space between the wheelboxes is 915mm, so I think that guard is much too narrow.
It could possibly be for a small van or maybe a Citroen Berlingo-type car/van? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
23rd May 2012 2:11pm |
ben_j85jty Member Since: 02 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
Hi Jon,
If Chris doesn't want it I'd be interested, but would probably be chopping it about a bit to fit behind the front seat in the DC. cheers Ben 2002 Defender 110 DC |
23rd May 2012 4:43pm |
Go for it Ben
23rd May 2012 6:16pm |
I'll give t a while to see if anybody wants to use it as intended, shame to play about with it if somebody has a propped use.
Besides, I seem to always get freebee's from Jon! 2002 Defender 110 DC |
23rd May 2012 6:20pm |
I would have had the bolt cutters on it Ben so..........before Jon gets fed up and backs over it
23rd May 2012 6:42pm |
Ben - it's yours mate.
Can drop off in Buckingham on way home from work one evening if that's easiest ? Drop me a PM or text when you around that way next . Jon - 110 td5 [sold]. Currently Defenderless. |
23rd May 2012 8:19pm |
Jon,
Will text to confirm but I am there all day sunday if that is any good? If you time it right I will be able to get you on the range for a shoot if you want a go? 2002 Defender 110 DC |
23rd May 2012 9:52pm |
would make an excellent "inside-rack" with a bit of chopping
24th May 2012 6:28am |
