Home > Maintenance & Modifications > Fitting a Mantec Cubby Box |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
A lot of after market kit does not come with instructions which is the bane of my life!
Have not fitted a Mantec box but will assume it is similar to other makes in fitting. Assuming you have the standard 'cubby tray' unscrew that and offer it up to the underside of the Mantec box and see if holes match up.. If yes it should be a straightforward fit job. Check carefully that you can operate gear lever and high low box lever without trapping your hand. Some cubby boxes with both a radio compartment and a drinks/trinket holders are too long to enable easy use of high low lever. One possible solution is to mount them further back then check does not protrude to far into middle seat rows. If holes do not line up, choices are to use cubby tray as a template and drill bottom of box or drill seat box for rivnuts. CHECK carefully for wires underneath before drilling MSS boxes comes with a pad of insulation foam for underneath the cubby box. Check measurements twice, check for wires twice, drill once. Brendan |
19th May 2012 1:41pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Also not fitted a Mantec,, but i did scan the instruction of a MMS one.. may help ??
https://www.defender2.net/gallery/displayi...;pos=-5979 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
19th May 2012 7:56pm |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
I used to have a Mantec box. Fairly straight forward to put in. I was replacing a centre tray rather than factory cubby box, and annoyingly only two of the four threaded holes in the centre seat box top lined up, but it's a simple matter to take it out and drill an additional two holes and fit the supplied rivnuts. (As long as you have a rivnut tool...) Peter
2008 SWB Truck Cab 1952 80" Soft top |
20th May 2012 12:44am |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
This may help - One I made earlier (as Blue Peter would say ... ) http://www.defender2.net/forum/topic8631.html John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
20th May 2012 10:18am |
