Home > For Sale & Wanted > FS: Door Connectors, Fusebox Terminals and Header Connectors
PaulMc
On eBay now -
DEFENDER TD5 / PUMA - Central Locking/Electric Windows - Front Doors Connectors
http://www.ebay.co.uk/itm/160803935514 - £18.95 + P&P
DEFENDER TD5 / PUMA - Central Locking - Rear Side Doors Connectors and Terminals
http://www.ebay.co.uk/itm/160803935596 - £7.95 + P&P
DEFENDER TD5 / PUMA - Central Locking, HRW, RWW, HL Brake Light - Rear Tail Door
http://www.ebay.co.uk/itm/160803935554 - £13.95 + P&P
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #124863 17th Feb 2012 11:08pm
PaulMc
Header Splice Connectors
In addition to the above, I have managed to source, a limited quantity of Sumitomo 20-Way Splice Connectors, as used in Defender TD5/Puma and several other Land Rover models as Circuit Headers.
These aren't on eBay - PM me if interested
They are available in six different colours, each colour denotes a different configuration (and number) of commoned circuits.
As well as being useful for replacing existing headers that may have been damaged or burnt, they can be used for expanding the number of connections to an existing circuit.
For example - you want to add more switches.
You can take all the new switch illumination and earth wires back to a new header, which is then fed from connections to existing headers.
If an existing header has no spare 'ways' on a circuit that you want to expand, you can release the terminal of the wire that feeds the circuit to that header, insert it into your new header and make-up a link wire from your new header to the terminal position that you've just relocated.
Although the splice caps on these are sub-divided into sub-circuits, you can easily change this configuration by inserting a short link lead loop between sub-circuits. Land Rover do this on several headers, to increase the number of 'ways' available at a particular header.
BLACK
Sub-divided into five circuits -
BLUE - BACK IN STOCK (August 2020)
Sub-divided into four circuits -
GREEN
GREY - BACK IN STOCK (August 2020)
Sub-divided into three circuits -
ORANGE
Sub-divided into six circuits -
YELLOW
Supplied (as pictured above) with a 20-Way Splice Connector, Splice Cap and 20 x Sumitomo 090 Terminals.
The Blue and Grey Headers are £19.95 each + Postage & Packing
The other colours are £12.95 each + Postage & Packing
Spare terminals can be supplied -
Terminals for 0.5 - 1.5mm² cable = £0.35 each
Terminals for 2.0mm² cable = £0.50 each
I'm happy to post anywhere in the world -
Contact me for the current P&P costs.
Thanks Martin Thumbs Up Paul.
Post #145670 18th May 2012 2:22am
PaulMc
I've also managed to source a similar compatible Terminal to fit into the unused ways on the Defender TD5/Puma Fusebox -
I have them to suit three different cable sizes -
0.5 - 1.0mm2
1.5 - 2.5mm2
4.0 - 6.0mm2
They're not identical to the terminals in the TD5/Puma Fusebox but, they're by the same manufacturer and they are a very close match - they fit into the fuse box with no problems, see my post here -
http://www.defender2.net/forum/post96207.html#96207
These are not on eBay - PM me if interested
They are £0.50 each (all sizes), or 5 for £2.25 + Postage
Post #145671 18th May 2012 2:39am
Burtbloggs
1987 Defender 90 V8 Petrol CSW Arles Blue
Do you still have these available?
Post #695362 22nd Mar 2018 6:47am
Sulisuli
His post was from 2012 so perhaps not, you may however be lucky. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #695363 22nd Mar 2018 6:52am
Send him a PM, Paul generally has a very comprehensive range of connectors available and is an exceptionally helpful fellow! Thumbs Up
Post #695377 22nd Mar 2018 9:30am
Burtbloggs
Thanks for your replies.
Being new to this forum I can’t PM him till have made 3 posts.
I’m not sure if this will count as my 2nd or what.
Post #695386 22nd Mar 2018 10:35am
Yes it will count. Only one to go. Thumbs Up
Post #695388 22nd Mar 2018 10:42am
Burtbloggs
Fantastic 😁
Post #695390 22nd Mar 2018 10:47am
Anderzander
I’d bought a few things from Paul over the years and he was always fantastically helpful - and then part way through a purchase he just disappeared.
I always hoped he was ok - and I hadn’t seen him post since, but looking here he’s had some recent posts - which is great news ! 😊
Post #695411 22nd Mar 2018 12:41pm
mk1collector
I've bought from him previously with great service but I'm not sure if he's getting his pm's as I've sent him a few in the last few weeks but they've not been opened or replied to. Hope he's ok. Ray
My build thread
Post #695458 22nd Mar 2018 5:50pm
LiftedDisco
If he doesn’t respond to this post, follow the link on his original post in 2012 to the eBay listing and then search ‘Seller’s other items’ and it will take you to current sales.
It would appear he’s still trading, even if he’s not a frequent presence on here...
Hope this helps...
Post #695461 22nd Mar 2018 6:18pm
