Home > Td5 > Slow td5
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Slow td5
A few issues
When the ignition is on there is a air hissing coming from the pressure regulator area
Also has any body ever had problems with the waste gate control valve ? Do defender td5s have them ?
And is there any reason why you can't get rid of it with a t-piece ?
Also when people say the engine is breathing heavy what are the signs ?
Kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #145432 16th May 2012 10:05pm
T1G UP
fuel pressure regs leak often. and can bypass so fuel pressure will be down...loss of power.
wastegate valve can be adjusted manually...they do stick open and shut...take it off and clean it up.
thats burning oil...check the breathers clear...crank case pressure can blow oil out.
Post #145438 16th May 2012 10:42pm
big steve
Cheers tig up least some one on here can help me
Will it have to be a complete new fuel regulator or parts to repair
Also I'll order a new waste gate valve for now or should I get the manuel one ?
Regards steve 2015 2.2 tdci hardtop xs
Post #145439 16th May 2012 10:48pm
Alive Tuning
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Havana
Fuel pressure regulators, replace as a complete unit. Buy genuine parts only! Exclamation
The boost modulator on the Disco is pretty cheap to replace, but rather than do that, just pipe it up as a Defender, with a single hose from the main turbo to intercooler feed pipe, direct to the wastegate actuator. Thumbs Up
Regarding the breather, take off the oil filler cap and start the engine. If there's a problem, You'll see fumes puffing out of the hole, usually in sync with a particular cylinder that would be down on compression. Normally there should be nothing visible, but maybe a very faint haze on high milers.
Post #145445 17th May 2012 12:07am
jst
fuel regulator, as above buy genuine and check VIN and they changed the design of them, they are all interchangeable but the reusable gasket wont fit between variants! so get a new one of those too.
quick and simple job to do. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145451 17th May 2012 7:14am
big steve
Cheers guys so anew set of rings might have Tobermory on order if it is what I think it is
Will the breathing lter the performance badly ?
Steve 2015 2.2 tdci hardtop xs
Post #145487 17th May 2012 11:27am
jst
if the rings are badly worn (FOD?) then yes performance will be down as your loosing compression.
so its down on performance? 50mph plus area?
what age is the td5 and mileage? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #145525 17th May 2012 1:45pm
big steve
It's a 1999 189k although I'm yet to check the breathing when I go to the workshop ?
I had the breather of yesterday and there was white steam type coming out but that was after being out on a 40 mile round trip with a trailer and disco 1 on the back so would think you could expect that ?
Yes it does seem a little down in hat area but drives pretty finest 70mph
Post #145528 17th May 2012 1:50pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hi Steve,
I doubt it is your rings, I would consider doing a check on all known common faults first. MAF sensor, MAP sensor, Fuel filter, Injector seals, Injector loom. Check your fuel pressure, Check your wastegate is not stuck or sticky. Check your oil for fuel in it (has the level risen?)
I just put a non genuine MAF sensor on mine and its going well now as mine was pretty slow. And the Nanocom figures suggested there was not a problem with it 50 ish at idle and 600 max.
If you have excessive blowby I would think the engine would be leaking oil like a sieve as the blowby pipe would not allow all the pressure to escape.
Steve
Post #145552 17th May 2012 4:50pm
big steve
Cheers guys I'm going over the shop tomorrow night so I will have a look
I've got a fuel filter
I recon the waste gate control valve is fluffed
Will order a loom part and from the sound coming from the pressure regulator I think that could do with changing as you can hear a hissing sound
So I will have a look
Post #145566 17th May 2012 5:42pm
