Home > Maintenance & Modifications > Louder after remap? |
Simple question (but one my searches didn't catch):
If a remapped Tdci develops significantly more power & torque, wouldn't you expect it to get louder too when you're using the extra? ALIVE and BAS customers all talk about improvements with smooth acceleration etc. (mine is also much better) but not overall volume. Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th May 2012 10:59am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2646 |
The engine clatters a bit more at low speeds, but nothing too over the top. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
14th May 2012 11:04am |
Yes
Mine makes a slightly louder "diesel tambourine" noise when cruising (not in the Biblical sense ) Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th May 2012 11:16am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5740 |
Mine became massively quieter once remapped, especially when working it .
Andy |
14th May 2012 11:27am |
Isn't yours that (very nice) TD5 90? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
14th May 2012 11:31am |
Yes mate
One of the advantages of remapping the Td5 is the lower volume. Andy |
14th May 2012 11:34am |
Mine too TDCi 2008 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
14th May 2012 1:54pm |
Any increase in noise levels get 'left behind' much quicker with the increase in torque, speed and bhp. The only way I would hear it would be if the Defender got stolen and driven past me.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th May 2012 2:03pm |
Drover Member Since: 27 May 2011 Location: Central Coast NSW Posts: 53 |
It is my understanding that the extra diesel clatter is a result of the increased common rail pressure. |
15th May 2012 3:39am |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1385 |
ours tends to growl.....a nice throaty noise Putting Dreams on Drives at JLR Solihull..
15th May 2012 8:19am |
Nope, Pete from BAS said: -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
15th May 2012 9:31am |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 654 |
So the same thing, just depends whether you're talking about common-rail or unit-injected engines
15th May 2012 9:33am |
15th May 2012 11:05am |
