- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
roadracingtog
I noticed the other day a drip of water from the bottom of the bulkhead channel (the door hinges are bolted through it). A squirt of windscreen washer, bright green in colour, ran along the gutter beneath the windscreen and then dripped onto the lower part of the windscreen hinge (?) It next reappeared from the bottom of the the bulkhead.
Is the bulkhead tunnel designed as a down spout to carry away water!
If not how is the water getting into the bulkhead? There's no water getting into the cab. The bolts securing the hinge are tight and the gaskets are in situ and appear OK.
Any advice on curing this? I have a couple of new gaskets, should I replace them? http://www.roadracingsupporters.com
11th May 2012 2:35pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
