Home > My Defender > My Defender 90 XS " The Dragon "
Page 2 of 2 <12
LR90XS2011
great mods I was considering the parking sensors in the jacking hole thing do the work OK ? Ive not done much to mine yet the but i have fitted a glove box conversion from Germany that cost £80 which is a bit steep but having fitted it im chuffed to bits and the Mrs keeps here mitts , sweets sunglasses etc in it. I also fancy one of those radios with the screen that comes out for DVDS and has a built in sat nav and will also allow a camera to plug in just got to find one for a sensible price thad does all main functions Radio, CD, DVD, SAT NAV and Camera
Post #67413 15th Apr 2011 9:18am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Hi Zagato,
Bumperettes were from Paddocks: http://tinyurl.com/3ow7g7p
However they need a 10mm spacer to clear the Bolt heads that are part of the rear seat mechanism/seat belt, unless Paddocks have changed the design recently. I did email them with the problem and pictures etc:. However my friendly Indy made up some spacers for me that did the job. Now guarenteed to make mincemeat of anyone who doesn't stop in time. Thumbs Up
Post #67660 17th Apr 2011 11:29am
WelshGas
Hi Defender OFTheEarth,
Whatever gave you that idea? Was it the Dragon? Laughing Laughing
Post #67661 17th Apr 2011 11:31am
Lorryman100
I'm about to get this one, there is another car only version. http://shop.snooperdirect.com/product1270186.html
Post #67662 17th Apr 2011 11:42am
WelshGas
Hi Kez,
Nice Defender { Black is Best }.
Fitted the reversing kit myself. The kit can work with 2,3 or 4 sensors. I used 2 and inserted them in the Hi-Lift jacking point in the rear crossmember using Ducktape to bulk them up and jammed in position. No holes to drill there. Wires went along back and into the cab via a hole in the rear OS by seat mechanism. Tap into reversing light feed at that point, also brought along rear from reversing light feed, and the control box and buzzer stuck on bare body panel just behind drivers seat. It also has a small LED sensor that I fitted to dash. Wires/plugs etc are of more than sufficient length and are robust. Will try and find the box in the garage and post with make etc: Thumbs Up
Post #67663 17th Apr 2011 11:46am
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Looking good Smile
Jack
Post #67666 17th Apr 2011 12:30pm
Kez
Isle Of Man
Cheers WelshGas, nice jon indeed. If I was to attempt it, it woudl burst into flames on the motorway (that actually happened to a friends car that I fitted a radio too back in the 80's - she was not impressed Shocked
Post #67668 17th Apr 2011 12:44pm
WelshGas
Hi Kez,
this is the one I have, made by Brigade.
http://www.brigade-electronics.com/product...r-system-2
Post #67670 17th Apr 2011 1:37pm
Kez
Isle Of Man
Thanks WelshGas, looks a tidy piece of kit too
Post #67675 17th Apr 2011 3:45pm
WelshGas
Hi Lorryman 100,
Nice piece of kit but I would be too worried about security. Confused
Post #67685 17th Apr 2011 4:43pm
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Does anyone have pictures of how the parking sensors are attached at the rear? Some people are putting them in the jack holes and some seem to attach them to the bumperettes.
Thanks 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #143906 8th May 2012 7:12am
WelshGas
The sensors with the kit I used, see previous posts, are rubber and designed to be inserted into a hole drilled in a plastic bumper. I just made them bigger by winding duck tape around them, then covering them in waxoyl and pushing into the hi-lift jacking points. Work very well. Thumbs Up
If you look very carefully at the photo of the Dragon, 1st post, and if you can zoom in on a photo of the rear view you can just make them out as they are black in colour. Thumbs Up Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #143964 8th May 2012 4:01pm
joelyates18
Wales 2000 Defender 90 Td5 HT Chawton White
Nice truck I'm also in South Wales! 2000 TD5 90 'Lemmy'
Happy Roving!
Post #207159 31st Jan 2013 7:08pm
WelshGas
Hi joelyates18.
I belong to the South Wales Land Rover Club. Members from all over S Wales. They meet on the 2nd Thursday evening of each month at 7pm at a pub just outside Cardiff. May be a bit far for you but they have members from Merthyr, Aberdare etc. If interested check them out here. http://www.swlrc.co.uk LANDYWATCH
Post #207191 31st Jan 2013 9:09pm
joelyates18
WelshGas wrote:
Hi joelyates18.
Cool will do Thumbs Up 2000 TD5 90 'Lemmy'
Happy Roving!
Post #207200 31st Jan 2013 9:36pm
Page 2 of 2 <12
