Home > Puma (Tdci) > Cigarette lighter socket, no keys
pcoote
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
I want to use the cigarette lighter socket to charge my phone without having to leave the ignition switched on, ie with no keys left in ignition. I could spend £2000+ on a dual battery system that would be overkill for what I need. Yes I will be careful with it. Is there a way to do this ?
Post #143918 8th May 2012 10:25am
Easy, replace the existing positive feed on the back of the cigar lighter socket with a fused permanent supply.
Which model Defender do you have (Puma / TD5 / 300) ?
Post #143919 8th May 2012 10:28am
pcoote
Which model Defender do you havev (Puma / TD5 / 300) ?
Cheers, it's a Puma
Post #143921 8th May 2012 11:01am
The Puma dash is easy to take out, just remove the two 'obvious' screws from the facia, the facia is then held with clips that require you to pull the facia forwards with your fingers gripping the moulding at the top above the centre airvents (note the heater turny controls stay where they are so dont try and pull them)
Once pulled forwards the rear of the cigar socket is easily reached and it is the centre spade connection that you are replacing. Just pull the old one off and put some insulation tape over the end of the redundant connector for protection (and to identify it if you want to reinstall at anytime)
A new 'Permanent' live can be found on the Hazard light switch, use a circuit tester (or somebody with the correct colour code will be along soon) - Scotchlocks are frowned upon so soldering would be better - make sure you run an additional fuse inline for safety's sake ....
Post #143922 8th May 2012 11:10am
Glynparry25
As above, spot on but personally I would take the permanent feed from the Stereo. Most have a secondary output (bullet connector) on the yellow wire.
At least then if you short it the stereo fuse blows and you just lose music.
Glyn Dog Sheep
Post #143924 8th May 2012 11:38am
Good point, I just wasn't sure that the Stereo feed would be 'man enough'
Post #143925 8th May 2012 11:42am
Better still run a new feed from the battery via an inline fuse. Not difficult.
Post #143927 8th May 2012 12:02pm
That would be good but not actually that easy ....
Post #143930 8th May 2012 12:05pm
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
I ran a 16mm^2 earth and live from the battery to the engine bay (Live is fused as close to the battery as possible). This wire is run on the outside, prperly armoured and tied down out of the way (Running on top of the ladder chassis. Here I installed a beefy 6 blade fuse box. From here I go back through the firewall (smaller wires) and thus have a seperate 12V that can handle ALLOT of Amps, should the need arise (eg. inverters etc....). I dont like to tamper with the existing wiring, and if that fuse goes you have to dismantle the dash again.
Post #143940 8th May 2012 1:06pm
or use the purple and black wires in the rear behind the speaker, and fit a socket there (Brendan has a good selection of 12v sockets) and you can throw a coat over your phone so it's not on display
and it's already fused Thumbs Up
Post #143993 8th May 2012 8:18pm
JSG
Another option is to run a seperate fused feed from the battery to the cubby box area and fit a socket there. It means that everything is in reach and it's easy to check nothing is left plugged in when you get out unless you want it to be.
 John
2011 Tdci 110 CSW XS
Post #144054 9th May 2012 8:24am
Not that it helps here, but an old Peugeot I used to have, on the fuse box you could pull the cigarette lighter fuse out and insert it in one of 2 positions, one gave permanent live, the other ignition switched.
Quite a handy bit of thought that was.
Post #144139 9th May 2012 4:52pm
