Home > Maintenance & Modifications > A decent subwoofer speaker or a 'bassy' speaker?
Page 1 of 4 1234>
RRUK
Now that I have installed my La Salle headlining and I have my 4 Alpine speakers wired up, I can finally listen to music again, which is brilliant. The Alpine head unit and speakers are incredibly crisp and clear, however it needs a little more bass.
I had originally dismissed the idea of a sub woofer,I certainly don't want a big box taking up a load of space in the rear.
What options do I have in a 90? I think I saw photos someone posted showing a big speaker in the back of a cubby (but they didn't have the bulkhead and I do, and the rear of my cubby faces my ECU, not sure it is a good idea to send thumping ohms at it!)
The box under the drivers seat seems wasted, could I put one in there?
Anyone got examples of good speakers that don't cost the earth? I think maximum of £100, as its not my daily driver.
Thanks all. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #143826 7th May 2012 6:00pm
K9F has an awesome ICE set up, when we're out with him, I leave my wireless off Thumbs Up
Post #143829 7th May 2012 6:05pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
If it were not for needing my centre seat I have seen a cubby with a pair of 10 inch one each side it still had a lid and enough space for a passport above the cones. Very sweet bit home made but still cool. Rhubarb and custard let fly with their secret weapon.
Post #143831 7th May 2012 6:10pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
I have a neat powered sub by Alpine, SWE1000, sits on back og my cubby box. Worth every penny BM52
Post #143838 7th May 2012 6:32pm
RRUK
This is where I am out of my depth, I don't understand the differences between powered/non powerwed/Active etc.
Having looked at the manual for my Alpine head unit (it's not a high spec model, its the CDE-120R) I have an RCA out port with the two audio sockets. Is this where I would plug in a Sub or do I need an amplifier too?
I have the feeling this will be more involved than I thought!
Alternatively I could just swap out my rear Alpine speakers for something with more bass to them, but again, not really sure what Shocked 2016 D4 HSE
Post #143845 7th May 2012 7:15pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
Another vote for the Alpine Powered Subs.
Essentially you can wither buy a sub speaker, fit it into some sort of enclosure to maximes the effect, and then run it off an amp or:
buy a powered amp, which has all three componets in one.
I fitted an alpine one which meant that I could fit a much smller amp to run the 2 6x9 speakers I have in the rear
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2002 Defender 110 DC
Post #143853 7th May 2012 7:48pm
bm52
this is mine
 BM52
Post #143858 7th May 2012 8:08pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
I have this Clarion
Very good...cheap...£60 Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #143861 7th May 2012 8:31pm
RRUK
lrmaniac, is that a self powered sub and speaker all in one?
I am liking the thought of one of those, I could mount that on the back of the bulkhead and then its out of the way. 2016 D4 HSE
Post #143864 7th May 2012 8:37pm
bm52
This from the Puma workshop manual.
"The Clarion® SRV313 sub-woofer is located on the cabin floor below the center cubby box and is secured to the floor
with two self-tapping screws.
The sub-woofer is connected to the head unit via a link cable from the head unit. Two phono plugs provide speaker
inputs for LH and RH inputs and are colored white and red respectively for identification and connect into the 'Input B'
sockets (the 'Input A' socket is not used). A power supply socket provides power and ground for unit power. A 'Remote
Control' socket allows for the connection of the remote control unit.
Remote Control and Auxiliary Socket"
I did consider this one but was advised by a local radio specialist to buy the Alpine for overall performance. prices were similar if i recall and both easy to fit. It's all down to personal choice. Confused BM52
Post #143865 7th May 2012 8:46pm
RRUK
I like the look of this and it matches my Alpine gear.
Approx how much did you pay? There are some on eBay for about £160. 2016 D4 HSE
Post #143866 7th May 2012 8:49pm
bm52
if i recall it was about £120-130 ish about a year ag0. Roadradio have a sale on...
http://www.roadradio.com/Alpine/SWE-1000/ BM52
Post #143871 7th May 2012 9:05pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Post #143873 7th May 2012 9:06pm
As above. Don't just look at Alipne they aren't the only one's out there. There is Kenwood who I'd personally recommend but also the likes of JVC Clarion ect ect. All have good points in different ways. The only time you could go wrong is if you don't buy premium brands I wouldn't suggest doing that or it may well be a buy cheap buy twice.
Post #143876 7th May 2012 9:13pm
RRUK
Thanks for all the advice, I think this is the way I will go.
The only hard part will be routing the RCA cables out of the dash to get to the unit, might need to take various bits apart to do that. 2016 D4 HSE
Post #143967 8th May 2012 5:22pm
Page 1 of 4 1234>
