![]() | Home > Puma (Tdci) > Limp home |
Reiver Member Since: 04 Dec 2011 Location: Cumbria Posts: 48 ![]() ![]() ![]() |
Could be a pre failure warning for the turbo, especially if you've had a re-map - not that I'm suggesting that would have been the case in my experience long in the past
![]() It could also be because above all, it's a Land Rover ![]() |
stumanuk42 Member Since: 04 Jan 2012 Location: Suffolk Posts: 8 ![]() ![]() ![]() |
it hasn't been remapped but i do about 24000 miles a year and half of them are dual carriage way, is there any way to see if it is that?
Nothing stressful about your mileage, marra. I think the elctronic brian is trying to tell you that some chip monitored thingamy isn't performing within the expected performance parameters. Early warning normally which needs checking soonest.
Stop me if I'm being too technical ![]() |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
It could be anything from a fuel problem to a faulty sensor, best thing get someone with a fault code reader to look at what faults have been logged and then take it from there. Richard
Either a 90, 110 or 130. Discovery 5 |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Chances are the MIL will go out after 3 ignition cycles unless the DTC continually fails the testing phase. You will need a diagnostic tool to read the stored tested DTC to narrow down the cause of the problem.
The engine will go into limp mode if it is overheating as a safeguard, but the fact that there is coolant in the expansion tank makes this unlikely unless the CHT sensor has failed or there is a blockage/issue with the cooling system? Did the temp gauge rise into the red? Other causes are failing MAF, MAP or the High Pressure rail control valve which can stick and cause high rail pressure, which relieves the rail pressure and trips limp mode. Reseting the ignition cycle will reset the limp mode and he MIL will go out after 3 ignition cycles though a tested DTC will be stored in the EMS. ![]() Brian. |
