![]() | Home > Puma (Tdci) > extended warranty |
jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87 ![]() ![]() ![]() |
should i do it or not.
it runs out middle of this month, the extended one works out at £61.50 month or £615 one of payment |
If you do, check ALL small print !!!
Approach with caution ! |
no - save the money instead
This has been covered more than once before....The general opinion was a resounding NO!
http://www.defender2.net/forum/topic7586.html?highlight=extended http://www.defender2.net/forum/topic10345.html?highlight=extended http://www.defender2.net/forum/topic4798.html?highlight=extended http://www.defender2.net/forum/topic3163.html?highlight=extended http://www.defender2.net/forum/topic4171.html?highlight=extended If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
