Home > Puma (Tdci) > extended warranty |
jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87 |
should i do it or not.
it runs out middle of this month, the extended one works out at £61.50 month or £615 one of payment |
4th May 2012 1:51pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
If you do, check ALL small print !!!
Approach with caution ! |
4th May 2012 2:13pm |
no - save the money instead
4th May 2012 4:53pm |
This has been covered more than once before....The general opinion was a resounding NO!
http://www.defender2.net/forum/topic7586.html?highlight=extended http://www.defender2.net/forum/topic10345.html?highlight=extended http://www.defender2.net/forum/topic4798.html?highlight=extended http://www.defender2.net/forum/topic3163.html?highlight=extended http://www.defender2.net/forum/topic4171.html?highlight=extended If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th May 2012 5:45pm |
