Home > Puma (Tdci) > How many time would expect your rusty bits to be replaced!
leonski
Dear all,
How many times would you expect LR to replace rusty bumpers, side steps, mud-flaps etc under warranty?
We have already had one set of flaps, bumper and one side step.
Now the bumper is flaking again the other side step is bubbling and the flaps are rusty as well as a rotten rear step.
I'm not sure when I'm starting to take the P*ss!
Leon.
Post #143261 3rd May 2012 8:24pm
Green Machine
Just keep going! LR are the ones taking the p*ss. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #143263 3rd May 2012 8:27pm
Happyoldgit
Keep at it until the warranty runs out and maybe beyond, it's disheartening to know that so much of the coated factory bolt on stuff these days is guaranteed to get shabby so quickly. Steve.
http://forums.lr4x4.com
Post #143264 3rd May 2012 8:38pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
..... LR may finally just get the message before they cease production 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #143288 4th May 2012 5:43am
Happyoldgit
That's highly doubtful. Steve.
Post #143316 4th May 2012 8:44am
MartinK
I must admit (sadly) that with 3 Land Rovers in the family (only 1 Defender) I kind of expect and worryyingly sometimes I seem to think it's normal. MrsK's Evoque is faring better than the Defender. My old Disco2 also fared better than the Defender!
But rather than replacing the bits, I've just been re-furbishing & re-finishing mine.
I used to use Hammerite & Waxoyl (on the Disco)
Now trying POR-15, Dinitrol & ACF with the Defender after the good advice on this forum (see Zag's excellent thread).
You shouldn't have to do this, but it seems the only way to keep it in good shape. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #143326 4th May 2012 9:51am
Happyoldgit
I would suggest that even with smothering everything with rust preventative [as I have done] the finish on some bolt on bits is still going to flake and rust. Mudflap brackets, side and rear steps, bumpers and such are currently just not prepared and finished to a high enough standard in the first place. Steve.
Post #143343 4th May 2012 11:58am
leonski
Thanks guys for reaffirming my thoughts and for your advice.
I have wax oiled, although, admittedly, a bit of a diy job and now wishing I had taken the time to outsource full under body protection....not that any of this would have saved the shoddy finish on all the bolt ons!
I would hate to see the state of it if it hadn't been looked after...
Started swapping out all the rusty bolts with SS that I got from Nakatenga and Stig, I just don't want it to start looking bling.
Rang Lloyds today and the are going to order all the bits in, not sure what I'm going to do with the weeping hinge pins though!
Cheers,
Leon.
Post #143425 4th May 2012 7:05pm
Green Machine
Leon - sadly the new parts that LR supply for you are likely to go the same way as your current ones in time. By all means have them replaced under warranty, but it may be worth considering keeping the old take-offs and having them blasted and re-finished professionally elsewhere. Depending on where you take them (and who is available to you locally) it shouldn't be overly expensive to have this done. That way, when the new ones flake and rust (and your warranty has expired) you will have a full set of shiny new bits to replace them with which are much better finished than the LR originals. I had my front bumper, rear crossmember (in-situ obviously), mudflap brackets professionally blasted and re-sprayed around 18 months ago and still looking exactly as they did when it came out of the paint shop (albeit with liberal coating of ACF50 every few months). 2005 Td5 | 90 Station Wagon | Tonga Green
Post #143430 4th May 2012 7:29pm
leonski
Hi Green Machine,
Sadly you are 100% right, I have already considered this, but i decided to keep going back until my warranty is up, then get the bits re-finshed professionally. I did consider asking if I could keep the old bits, but presumed that they would go back to LR, maybe I should have!
Not sure what finish to get eventually though, what did you have applied?
Cheers,
Leon.
Post #143431 4th May 2012 7:42pm
Green Machine
I just had mine blasted back to bare metal and then re-sprayed with a couple of coats of primer and a couple of coats of satin black. Had it done by a local place who specialize in classic car restoration. Have to say they did a top job. IIRC it was around £300, but that included some bodywork touching up as well - oh and the spare wheel carrier too. Powder coating would be a good alternative if you have someone reasonably local who could do it - would probably give a more uniform and tougher coating than paint. Depends on what paint is used I suppose.
As far as I'm aware, you are within your rights to request old parts taken off your vehicle be returned back to you, although that may be different for warranty claims? Perhaps someone can confirm that. My local indy always keeps any parts he's taken off mine to show me afterwards - just because he's like that. He also keeps all the boxes of the genuine parts he's used to show me too. There aren't many main dealers who would bother with that sort of thing. Anyway, hope that's helpful. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #143440 4th May 2012 8:10pm
Myo
South Africa 2010 Defender 90 Puma 2.4 CSW Stornoway Grey
Noticed some rust spots on rear mudflaps and some underbody bits too! So one could rightly take it to the dealer and they will replace it but I don't want to be leaving my van there every few months until the warranty runs out! Exclamation
Post #150485 15th Jun 2012 3:05pm
Never bothered
Post #150486 15th Jun 2012 3:05pm
Grockle
3 sets of steps (all 3),2 pairs of rear mudflaps, rear cross member resprayed, 3 pairs of mirror arms, numerous bolts (now replaced with stainlees ones) 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #150492 15th Jun 2012 3:15pm
K9F
It is frustrating and inconvenient continually going back to the dealers to get inferior items swapped out...I tired of it even before my warranty ran out. Here was my 'spin' on it and I'm still doing it now....
K9F wrote:
You can't make a silk purse out of a sow's ear and Land Rover has tried just that with the quality on certain items, as they are cr4p. Headlight bezels, sidesteps, front bumper, window hinge blocks, mud flap brackets, OEM A-bar brackets and wing mirror arms to name but a few. In my experience swapping out under warranty is just a 'sticking plaster fix' and the problem will undoubtedly reoccur sooner or later. I have either purchased quality after-market items or had the offending items removed and either chemically cleaned or blasted and a decent powder coating carried out for reasonable cost. (For example only £20 for a steering guard and A-bar brackets). Attention to detail is in my opinion what the Land Rover Quality Department lacks (if indeed there is such a department) and an eagle-eyed owner is much better placed to achieve the required standard of finish expected. For me I feel I am finally getting there after three years of ownership ironing out the minor issues myself. Thumbs Up
Still 'getting there' now..... Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #150501 15th Jun 2012 3:27pm
