Home > Puma (Tdci) > Turning ligths doesn't work |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 |
Friends
Today in the afternoon, the turning lights just stopped to work. No signal in the panel and no ligths outside. When I press the hazard button the ligth in the button works OK, but again no signal in the panel (both arrows doesn't ligth) and no ligths outside. Some with the same problem? Some idea about where is the problem? Anyway tomorrow will be the 60,000 km check, so I hope they can solve it in a good manner. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
11th Aug 2009 11:32pm |
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 |
Hi Eduardo,
I assume that you have checked the fuses (from memory there are two for the turning lights and one for the hazard circuit). I have had an issue with this occuring and also blowing a high beam light fuse. It turned out to be a short circuit in the wiring behind the dash. The dash was taken out and the offending wire was mended and sheathed. Hope it can be easily fixed. Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
12th Aug 2009 7:01am |
Finally was the flasher unit relay.
So, was a easy issue. Cheers!! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
16th Aug 2009 8:45pm |
