Home > Puma (Tdci) > Turning ligths doesn't work
Eduardo
Friends
Today in the afternoon, the turning lights just stopped to work. No signal in the panel and no ligths outside. When I press the hazard button the ligth in the button works OK, but again no signal in the panel (both arrows doesn't ligth) and no ligths outside. Sad Sad
Some with the same problem? Some idea about where is the problem?
Anyway tomorrow will be the 60,000 km check, so I hope they can solve it in a good manner.
Cheers Eduardo
Post #14093 11th Aug 2009 11:32pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
Hi Eduardo,
I assume that you have checked the fuses (from memory there are two for the turning lights and one for the hazard circuit).
I have had an issue with this occuring and also blowing a high beam light fuse. It turned out to be a short circuit in the wiring behind the dash. The dash was taken out and the offending wire was mended and sheathed.
Hope it can be easily fixed. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #14096 12th Aug 2009 7:01am
Grockle
Hopefully it will just need a new switch,then it will be have they got on in stock? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #14103 12th Aug 2009 8:32am
Eduardo
Finally was the flasher unit relay.
So, was a easy issue.
Cheers!! Eduardo
Post #14310 16th Aug 2009 8:45pm
