Home > Puma (Tdci) > Hazard lights switch |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2101 |
it does when the head lights are on ...
give that a try and see Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
1st May 2012 5:53pm |
Take a look at this thread http://www.defender2.net/forum/topic12482.html Pretty sure that the hazard button itself does not flash, just the red triangle on the dash plus both left/right green turn signal lights will flash. But my hazard button itself is not even backlit when the lights are on, sitting there as a black spot in the middle of the green backlit buttons. From the above thread seems that is definitely wrong. Still not resolved though. By the way, is it possible to pop out the hazard switch button from the dash without removing the center console cover? Or is it necessary to unscrew the entire cover (2 screws) and remove? If the button by itself can be removed easily, anyone can say how? You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st May 2012 7:45pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Damn. Always end up missing threads like that, I need to up my defender2 addiction again.
Just tried it now, mines only backlit with the lights on, and doesn't blink with the hazards on. Must have just been having a subconcious flashback to another car... I think if you remove the radio you can push the buttons out from behind. I know you definately can with the rear window demist as I knocked it out when trying to tidy the wires up a bit when I changed the stereo. |
1st May 2012 8:13pm |
Just ordered some replacement bulbs part# STC1205 from Rimmerbros in UK as PaulMc suggested in the other thread. If the dealer apparently does not know what to do and pretends the hazard switch is not backlit , we will try to solve it ourselves
Just not looking forward to loosen the center console cover in order to extract the hazard switch though You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st May 2012 8:45pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20292 |
The centre dash isn't hard to remove and replace at all. Have a look in my gallery and you will see it removed. It will also give you an idea of how it does remove by seeing the clips ect.
1st May 2012 8:47pm |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
I'm pretty sure the switch does pop out. If not, the centre treatment console is really easy to remove. The two T30 bolts and then you have 6 push fit clips. Two either side at the very top. Pull this out first and work down. Two more near the windows switches and two at the bottom which you shouldn't have to take out anyway.
Edit : Beat me to it |
1st May 2012 8:52pm |
Thanks for that. Do you need to take the radio out first? You never actually own a Defender. You merely look after it for the next generation.
2nd May 2012 3:37am |
