Home > My Defender > What Did You Do In Your Defender Today |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20490 |
All of it probably there only tie down straps there is also a proper rachet too for heavier items and a higher break strain. Here: http://www.flatdoguk.com/cargo-strap---3mtr~403
1st May 2012 2:30pm |
It's all about slagging other peoples products off!
1st May 2012 3:21pm |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
I assume that was aimed at me .... quite the contary, you are mistaken, I think it is a well priced item, if the load quoted is for the pin as well then I will be buying some |
1st May 2012 3:51pm |
I stand corrected
1st May 2012 3:52pm |
At ease ....
1st May 2012 3:53pm |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
By the looks of it the webbing is attached to the cam lock by going around a solid part of the casting rather than a "pin" so probably pretty decent. I'd have thought that the breaking strain is for the whole item rather than individual components, my climbing harness is rated for the whole item, individual parts are not tested separately unless supplied separately. I think I'd rather buy from these guys - made in the uk rather than a cheap Chinese copy, which would most likely me made from straw and recycled coke cans! Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
A lot of there branded gear seems very good value ...
1st May 2012 3:58pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
That's a beast ! What's going in the back on your first trip ? It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
1st May 2012 4:23pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
4 large quads California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
1st May 2012 4:27pm |
Oooh that's nice ! You are welcome, shame I can't make it this time, can't wait to get out on the Grizzly again Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st May 2012 4:33pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Webbing assemblies are normally rated by its weakest link.
1" cam lock buckles are typically rated at 450kg. 1" polyester webbing strength can easily have a strength in the region of 1200-2000 kg With these types of cam lock straps I would suggest that one very like failure mode is for the webbing to actually slip through the cam buckle rather then anything breaking. However I have not broken any webbing assembly in a controlled manner recently Brendan |
1st May 2012 4:40pm |
BIGFOG Member Since: 12 Sep 2010 Location: Edenbridge Posts: 537 |
On site in Telford fitting a new fogging system, glad to be under cover with the weather we had!!
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2009 XS 110 Utility Stornaway Grey BAS re Remap, BAS Turbo, BAS Spec Modified Airbox, Twisted Side exit Decat Exhaust, Allisport Cooler and Hoses, OME Sport Shocks, Kangaroo Paw Discs. 2001 Discovery II Porsche Speedster Replica 1956ish |
1st May 2012 6:40pm |
ok, silly question, what's a "fogging system" and why do people want them?
1st May 2012 6:45pm |
Look up Pendred Fogging on YouTube and you'll find various clips of our fogging units in Farmers Coldstores as today, in Morrisons, in Farm shops etc. The basic principle is to saturate the atmosphere with fog made of nothing but water and keep vegetables hydrated whilst they are kept in store. Lots of salad and brassica farmers use it, most of them in fact! Hope this helps?? 2009 XS 110 Utility Stornaway Grey
1st May 2012 6:53pm |
