Home > For Sale & Wanted > REVERSING SENSORS FOR THE TDCi |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5006 |
Even better Sensors don't always work on bollards/corners etc
http://shop.reversingcamerasuk.com/epages/...tAodH0Bi_Q A search should bring up a few good threads on this... |
30th Apr 2012 6:40pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Have a wireless version for sale with 2 cameras
£180 |
30th Apr 2012 7:02pm |
Gil9713 Member Since: 11 Sep 2011 Location: Colchester Posts: 94 |
Thanks lads, which system is the £180 one you have, any specs with it, as I didn't really want to have a monitor on show on the dash?
30th Apr 2012 8:30pm |
this one
http://shop.reversingcamerasuk.com/epages/...ra_systems 6 months old, 2 cameras, not 1 |
30th Apr 2012 8:35pm |
Thanks for that, was really looking for a simple tone indicator rather than having a 7" monitor on show or having to hide it every time.I will look at knocking something up linked to the reverse gear which looks like the most sensible way to progress Thought there might have been something around already
1st May 2012 7:41am |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 |
There are a few recommendations on here somewhere, but from what I gather there are some adhesive ones which won't require any drilling. Some of the inset ones say not suitable for steel bumpers for some reason, so this might be a better option. Danielle Gardel has a set fitted on his wagon so there are also pictures somewhere.
Dolphin parking sensors are the ones http://www.parkingsensors.co.uk/adhesive_p...udio_2.asp There is a 2 pc set and a 4pc set, with or without a a display, priced from £29.99 so it looks like a reasonable way of getting a simple backup sensor. If I come across the other thread I'll add to this post. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
1st May 2012 8:55am |
Here's the thread for the Dolphin ones, look pretty neat and have some recommendations as well.
http://www.defender2.net/forum/topic4457.html?highlight=sensors DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
1st May 2012 9:01am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3479 |
I'm just fitting some bumperettes! 1951 80" S1 2.0
1st May 2012 9:21am |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I fitted these
http://www.parkingsensors.co.uk/adhesive_p...udio_2.asp Very simple - just spliced the power into the reversing light positive feed. The buzzer sounds about as cheap as you can get but it's quite funny really - nicely in keeping with the rest of the Defender trim. I only used 2 but you can get 4 for better detection of lamp posts and bollards. If you have bumperettes or a swing away carrier, make sure you test where you're mounting them before sticking them on so they can't "see" your accessories. HTH Alan One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
1st May 2012 9:29am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Rear bumperettes are good for reducing damage to your vehicle and/or doing damage to object which has hit your vehicle/been hit by your vehicle.
Reversing sensors are about 10/12 mm diameter which are a snug fit into a tube. The tube can be attached by a screw to the underside of good rear bumperettes and the sensor is at the outermost face of the bumperettes. No problem with false signals from bumperettes or spare wheel. Brendan |
1st May 2012 10:32pm |
I have dolphin ones on my truck, I mounted them away from the metal parts on my NAS step using black plastic spacers, works a treat.
2nd May 2012 7:32am |
xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258 |
Just make sure if you fit them, that you don't put them directly behind where the rear foldaway step goes when you fold it up - unlike the previous owner of who fitted some to my 110. Just means you can't fold up that step!!
It took me a worryingly long time to work out why it was constantly buzzing when I was reversing... Still working out the distance to angriness of buzzing ratio, but I have 4 and a camera and I so far haven't hit anything! |
2nd May 2012 10:50am |
Cheers to all for thier comments. Just recieved what Alan suggested this morning in the post £29.99 plus P&P.
Look just the job and easy to fit Gil |
2nd May 2012 3:58pm |
jayaway44 Member Since: 04 Nov 2011 Location: Edinburgh Posts: 111 |
So have you fitted these yet and how do you find them, did you fit 2 or 4 and do you have any pictures of them fitted as that would be useful. Thanks |
8th May 2012 6:31am |
