Home > Puma (Tdci) > Gear box noise - idling in neutral
tmcwhirter
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I am starting to notice a change in the sound when idling in neutral. May have been there the whole time and have never noticed it but wanted to check to see if anyone thinks its sinister as I'm coming toward the end of my warrantee.
Symptoms are as follows:
- In neutral, clutch in, normal idle
- Drop the clutch, idle gets slightly rougher, tachy drops momentarily
- Slight change in noise / vibration. Can's quite tell if its coming from the gearbox or clutch
Would appreciate some thoughts before attacking the dealer on it.
Cheers!
Post #142555 30th Apr 2012 11:17am
MK
Likely to be the friction plate. Second chance is the input shaft´s bearing (more unlikely). Puma 110" SW
Post #142572 30th Apr 2012 3:08pm
tmcwhirter
Thks for response. So if its the friction plate, thats just a matter of adjusting the play then?
Post #142575 30th Apr 2012 3:18pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
New clutch Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #142576 30th Apr 2012 3:25pm
tmcwhirter
Thanks - that's what I was after. Won't be taking no for an answer with the warrantee coming up. Only got 15k miles on it!
Post #142577 30th Apr 2012 3:27pm
MK
If it turns to be the clutch please tryto cast your vote here http://www.defender2.net/forum/topic12243.html
A pic from the plate would be also appreciated Thumbs Up Puma 110" SW
Post #142580 30th Apr 2012 3:52pm
tmcwhirter
Will do
Post #142591 30th Apr 2012 4:23pm
billewizz
run a gt3rs and listen to that on tick over, the whole world sounds like a swiss watch.
Post #143258 3rd May 2012 9:04pm
