Home > Puma (Tdci) > Gear box noise - idling in neutral |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2395 |
Likely to be the friction plate. Second chance is the input shaft´s bearing (more unlikely). Puma 110" SW
30th Apr 2012 3:08pm |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 |
Thks for response. So if its the friction plate, thats just a matter of adjusting the play then?
30th Apr 2012 3:18pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
New clutch Original Member Pie n Pea Club.
110 HCPU Tipper |
30th Apr 2012 3:25pm |
Thanks - that's what I was after. Won't be taking no for an answer with the warrantee coming up. Only got 15k miles on it!
30th Apr 2012 3:27pm |
If it turns to be the clutch please tryto cast your vote here http://www.defender2.net/forum/topic12243.html
A pic from the plate would be also appreciated Puma 110" SW ............................................................. Earth first. Other planets later |
30th Apr 2012 3:52pm |
Will do
30th Apr 2012 4:23pm |
billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 66 |
run a gt3rs and listen to that on tick over, the whole world sounds like a swiss watch.
3rd May 2012 9:04pm |
