Home > Tdi > Veg oil? |
can be tricky in the winter, but works well in the summer.
26th Mar 2012 6:51pm |
scamp Member Since: 05 Feb 2012 Location: Lincolnshire Posts: 29 |
Just picked up my 300tdi today - all be it not a Defender but a Disco - once all the service work has been done it'll be time to try the SVO / Dino blend
21st Apr 2012 10:06pm |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
So when you factor in new pump seals, recon injectors, more fuel filters an changes and more engine oil and changes one really needs to be doing a pretty high mileage for there to be much of a saving? I have to remain unconvinced on this one, also let's not forget that the basic design of the tdi took place in the 1980's and back then dino diesel was the only common type and as such is what Bosch designed the fuel system for. Rhubarb and custard let fly with their secret weapon. |
22nd Apr 2012 6:10am |
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 |
SVO won't harm the pump seals, or any other seals, BUT the chemicals they put in Bio will. I tried morrisions B20 a while back, (20% bio,80%dino) and within a week the seal on the tank around the sender unit started to weep. I stopped using it straight away, and stuck to svo, and it healed itself.. More fuel filters? Oh no, only the first one, then its business as usual. More engine oil and filters? Oh no, 5-6k as usual. Injectors? mine are 130k old now, and prob nearly 30k on svo blend. Passed Mot on fri at 1.41 ppm smoke density, or whatever it is. I take it you don't partake of the veggie blend then? So why are you reading this topic? |
25th Apr 2012 4:45pm |
I read the thread in the seemingly vain hope that someone with the research and development budget of say Bosch or land rover could offer me a sound and reasoned scientific argument that alternative fuels to those an engine was designed for were safe to use, instead of another back street hero trying to tell me that they and or their mates have done such and such for ages with no worries. Sorry, I'll take my leave and let you get back to finding the next miraculous way to save 10p a week.. Rhubarb and custard let fly with their secret weapon.
25th Apr 2012 7:48pm |
Funny , I'd have thought that coming from Yorkshire, 10P a week, would be twice your annual salary. I'm not asking you to try it! I'm not selling it! I didn't start this topic! I have used it for 3 years! I have had no problems! Now tell me what fuel Rudolph Deisel designed the engine to run on? PLEASE don't say Shell V deisel. |
26th Apr 2012 8:11pm |
Really, that's the best you can do? Oh well never mind. As to what our man designed his proto engine to run on, that has no bearing on what Bosch designed some 90 odd years later does it, honestly? Rhubarb and custard let fly with their secret weapon. |
27th Apr 2012 6:02am |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
Am I missing something ?, isn't it illegal to run on Veg oil unless you pay HMRC the duty. Richard
Either a 90, 110 or 130. Discovery 5 |
27th Apr 2012 8:41am |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
Yes, you are missing something. You can use up to 2500l of vegie oil for personal transport use without informing HMRC.
27th Apr 2012 10:36am |
Thanks, learnt something new. Richard Either a 90, 110 or 130. Discovery 5 |
27th Apr 2012 2:52pm |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
you can allways make diesel from used engine oil, trucking firms have loads of the stuff to give away. The process is a bit more messy though.
Pom |
27th Apr 2012 3:11pm |
I think you'll find that that IS illegal. IIRC where as veg/bio/blend is tax exempt up to the 2500ltrs pa (this is per person mind you, so a partner has the same alowance, = 5000lts pa) because it is a fuel substitute, mineral oil derivatives are a definate nono, (vehicle confiscation/huuuuuuge fine type naughty.) I have had occasion to tip a wee bit of filtered engine oil in t'tank for a bit of looberication!!!! Does stink tho! Not like nice vegy smell. Different oils smell differently, some smell chippy, some smell burgery, some smell doghnutty! cant remember which is which now. I only travel about 7-8k pa, but my '10p a week' saving equates to at least my annual road tax and mot costs. But I wouldn't bother if I were you. |
27th Apr 2012 5:52pm |
its perfectly fine as its diesel not mineral oil when used.
Obviously you cant just dump used engine oil in the tank. Check out fractional distillation for the howto. Pom |
27th Apr 2012 7:41pm |
This alternative fuel thing really does seem to be a bit of an underground subject.
As most reading this post, me included, are seeing there are many different opinions as to what is the correct answer. There are also so many different forums offering arguments for and against the use of Biodiesels and veg oils and to be honest I am suffering for major information and misinformation overload. There is one particular forum that I go on that advocates the use of SVO, WVO and homebrew Biodiesel and from what I have gathered from posts on there some engine / injector pump combinations are not as happy with veg oil as others. Mind you, that said there are some injector pumps that are not happy with standard pump dio-diesel due to the serious lack of lubricating agent in modern diesel and this leads onto yet another underground type subject of adding motorcycle 2 stroke oil into the tank to combat this "dry" fuel. I am going to try blending new SVO with pump fuel - starting with a low percentage of veg to begin with - and see how it goes. |
27th Apr 2012 9:57pm |
