Home > Puma (Tdci) > TDCI Engine Spares |
fixit Member Since: 15 Mar 2012 Location: Sunny devon Posts: 66 |
Hi just a quick up date the engine didn't last long before it done the same again
So we have stripped it down to find this time there was a pattern of carbon like a 4 leaf clover on the piston and there is a bright clean line across the middle 1/2 an inch wide that suggested the injector was leaking So we have re built it with new injectors all 4 of them and now have 100 miles on the clock and it is running well fingers crossed it will carry on |
25th Apr 2012 7:33pm |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
good work, stripping it down and sorting it your self. i thought everyone said these 2.4 engines are impossible to work with!
25th Apr 2012 7:45pm |
There not to bad really we have a few transits and the tdci and the older tddi engine isn't much different apart from the common rail and the electronics
The older tddi engines we have developed injector problems and 2 of them cracked pistons and run up on there own oil it gets quite exciting stalling one in gear when reved out and screaming Both of them had one replacement piston and a set of injectors and rebuilt. One of them i still have and it has done more miles since the rebuild then it did before. The other one broke the timing chain after 30k miles a warning that now means i only fit genuine parts in the engine. (If you can count fitting landrover bits) |
26th Apr 2012 6:11pm |
