Home > Maintenance & Modifications > Eberspacher D2 Heater |
Nick T Member Since: 29 May 2011 Location: Bolton Posts: 203 |
It's an intersting thought. Certainly got my thought buds going....
Can't see it being practical but worth a ponder |
25th Apr 2012 6:29pm |
McS Member Since: 05 Oct 2009 Location: Banbury Posts: 686 |
my mate has his eberspacher mounted to the rooflining of his 130 crew cab and then just runs a piece of ducting from the outlet through an open window and up to the rooftent at night, works a treat.
Ross The Scotia Winch Challenge |
25th Apr 2012 7:09pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
They get hot! Very good hot air supply and you can get small tanks off eBay
25th Apr 2012 8:33pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
yeah there brilliant things, especially on frosty mornings.............set the 7 day timer and its toasty when you jump in
25th Apr 2012 8:46pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
It takes 7 days to heat up ?/!!
25th Apr 2012 8:48pm |
no you can set it to come on upto 3 times per day, each day of the week |
25th Apr 2012 8:51pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
Hi,
I fitted mine inside my cubby box, all electrics are contained inside it so it can be removed easily but not conveniently. I made a 3 way manifold at the rear which distributes the warm air. Pipes go out side windows into the roof tent. As said it does get hot 2kw hot, but the body itself is not. Worked well in the cubby, I was mindful of it overheating in there. Take a look here, sorry you may need to join to view pictures. http://www.expeditionportal.com/forum/thre...ight=Espar Steve |
26th Apr 2012 8:11am |
kevb Member Since: 03 Apr 2012 Location: AllPackedUp Posts: 34 |
This might give you some ideas.......
http://www.adventuretrailers.com/heaters.html |
5th May 2012 3:02pm |
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 |
I thought about this too - my thought is to use a simple 12V fan, some flexible 4" ducting (like a tumble dryer pipe), a bespoke plate to put the pipe/fan onto a half open rear window - and then just pipe it into side window on the roof tent
Keeps all the nasty hot things and exhaust etc away from the tent - and you have a nice warm truck too |
5th May 2012 6:10pm |
roamingman Member Since: 15 Mar 2012 Location: nearly thier Posts: 152 |
Hi steveb tryed the link did not see any photos, edit did not think to log in, senior moment, Live Life Ti'l You Die Teddys are out thier http://teddybearspicnic.webs.com http://130sasha.co.uk/ |
6th May 2012 10:59am |
