Home > Technical > Door leak - any ideas ?
bob neville
I have a problem with the passenger door on my 110, I have water leaking from the bottom of the door card which ends up under the carpets/mats.
I have taken the door card off and the membrane is perfect and sealed. I taped all round the edge to make 100% sure it was sealed.
Shut the door and blasted with the hose but could not find where the water was coming from.
Anybody got any pointers as to where to look for the fault, I think the problem is around the window somewhere but I can't pinpoint it.
I should add that this door has had work done on it by the dealer so I am sure it is something that has not been put back correctly.
Ta
2013 Defender 90 CSW - sold
Post #140938 22nd Apr 2012 6:30pm
Zagato
Maybe process number 7.2 from the Water Ingress Manual, a few other door leaks noted also!
http://www.zee-rover.nl/downloads/water-ingress-manual.pdf
I keep losing a link to the Puma water ingress manual Sad might be worth a look if you can find it anywhere!
Edit - here it is https://www.defender2.net/gallery/albums/u...cedure.pdf
Post #140944 22nd Apr 2012 6:40pm
bob neville
Could be Thumbs Up
Only confusing thing is the water is between the inner membrane and card but ........ it is probably finding the path of least resistance.
Post #140954 22nd Apr 2012 7:08pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Timely post this, as we have now, last 3 /4 days found a large puddle in the rubber tray /drivers footwell, with water seeping from the area of the door stay/ ,bulkhead area. No seepage apparent when in motion, just when parked overnight
Many thanks “Zagato “, as I was planning on having a search or post on this.
Post #141017 22nd Apr 2012 9:43pm
Zagato
Thumbs Up It's always worth posting up.
Post #141102 23rd Apr 2012 12:59pm
BigRuss
Have you tried hosing it down with the window open? Russell
2011MY 110 XS USW Black
Post #141125 23rd Apr 2012 2:38pm
JSG
Rolling with laughter Rolling with laughter John
2011 Tdci 110 CSW XS
Post #141141 23rd Apr 2012 3:31pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Couple of thoughts
1 - Quite a lot of people report internal condensation and or leaks that start on the roof - i wonder if this may run down the internal window?
2 - You could use duct tape over all the affected area (ie joins, seals etc) and remove a strip periodically until you can detect the leak again
S
Post #141460 24th Apr 2012 7:22pm
MK
That is the LR cat hiding behind the membrane. Hammer a bit the door and solve the problem. Puma 110" SW
Post #141475 24th Apr 2012 8:10pm
Ravers
This problem annoyed me and gave mrs ravers good opportunity to nag nag nag. took it to the stealers, who, ahem 'fixed' the problem until it rained the next day. 'Big Cry'
I remembered when i picked up our new defender that the door seals often fell out, wife would nag, and i'd put them back in. one day i glued the sods in. that was the problem, i'd glued the seals to far back (only mm's) from the front pillars (windscreen). the fix was to remove them, clean and seal in place with silicone.
the dealers apparently liked it so much they offered to remove and re do the job themselves 'Rolling Eyes' i told them to rod off.
since the seals often fall out, it may be worth a try, good luck Ravers
Post #145190 15th May 2012 7:55pm
bob neville
Thought I had at the weekend Laughing
Hosed the door glass only, opened the door and a torrent of water ran out Shocked
Filled the gap between the outer glass seal and the door with Dum Dum and the leak has virtually gone. Dealer did some work on this door last year and my guess is it is that work that has caused the problem.
In for 3 year service and MOT on Monday and also this problem. As the warranty is just about to finish they can either fix it (plus the window that does not fit properly anymore) or replace the door.
Post #145193 15th May 2012 8:06pm
